iPhone 4 Verizon Home Button Replacement
Выберете то, что вам нужно
  1. iPhone 4 Verizon Home Button Replacement, Rear Panel: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    Pra descarregar a bateria, antes de fazer o serviço, isso serve pra qualquer celular?
    Gilmar Dutra - Ответить
  2. iPhone 4 Verizon Home Button Replacement: шаг 2, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 2, изображение 2 из 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Verizon Home Button Replacement: шаг 3, изображение 1 из 1
    • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
  4. iPhone 4 Verizon Home Button Replacement, Battery: шаг 4, изображение 1 из 1
    • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
    you do not need to take the battery out as chuck said so you dont run the risk of braking the battery connector socket from the logic board
    22therealala - Ответить
    Won't you need the battery removed to access the large-headed screws on the side which hold the front display?
    Casey Baierl -
    In my situation, the #00 screwdriver had a hard time trying to get the screws off. Using a glasses screwdriver kit may be a better alternative if the screws are resistant to the #00 screwdriver.
    tjaeger - Ответить
    Unfortunately the battery screw was already stripped probably from original assembly. We used a pair of nail clippers as pliers to grab a hold of the screw by the edges to turn it. If it hadn't have been for the stripped screw it would have taken us about 10 minutes, as it was it took us 30-40 minutes if you count searching for solutions for removing the stripped screw.
    Margaret Burruss - Ответить
  5. iPhone 4 Verizon Home Button Replacement: шаг 5, изображение 1 из 1
    • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
    I don't see the metal clip covering the antenna connector, in the photo or in my phone. Hope this isn't a deal breaker.
    Gary Tash - Ответить
    I don't see it either. I think the metal clip is on the model A1332. The GSM model.
    mcr4u2 - Ответить
  6. iPhone 4 Verizon Home Button Replacement: шаг 6, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 6, изображение 2 из 2
    • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
    Note that the pull tab is not actually attached to the battery. It is attached to the iPhone chassis, and is only used to separate the battery from the adhesive. (Don't expect it to come out with the battery!)
    Also, the adhesive is VERY strong. I had to use my plastic opening tool to assist in prying the battery loose. This is probably the most nerve-wracking part of the job.
    Matt Strange - Ответить
    It is much easier to slightly WARM the battery with a HAIRDRYER not a HEAT GUN to soften the adhesive. DO NOT GET BATTERY HOT AND DO NOT USE HEAT GUN
    Joe -
    I just did this today. Everything was as scripted. Mine had lots of adhesive and had to use plastic spudger to go around battery to loosen up. Do not use plastic tab until you can see under battery a little bit. Great instructions. Took less than 10 minutes.
    kamullins4135 -
    The adhesive is very strong and I was initially worried about damaging the phone by prying so much. There are a couple of places below the volume switch where you can pry between the metal of the case and the battery. If you lift the battery just a little, wiggle the pry bar further in and then start moving down the case. Don't worry about bending the battery, its dead anyway.
    Do not pry on the left side (circuit board side) and do not use the pull tab until the adhesive is broken loose.
    martin474 - Ответить
    I tried this at first with a plastic pry tool, and the adhesive was so strong that I broke the tool. I then used a large screwdriver and applied pressure very slowly along various places on the outer side of the battery. That eventually did the trick.
    alsmith1928 - Ответить
  7. iPhone 4 Verizon Home Button Replacement, Dock Connector Cable: шаг 7, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement, Dock Connector Cable: шаг 7, изображение 2 из 2
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
    • Remove the thin metal dock connector cable cover.
  8. iPhone 4 Verizon Home Button Replacement: шаг 8, изображение 1 из 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  9. iPhone 4 Verizon Home Button Replacement: шаг 9, изображение 1 из 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  10. iPhone 4 Verizon Home Button Replacement: шаг 10, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 10, изображение 2 из 2
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
  11. iPhone 4 Verizon Home Button Replacement: шаг 11, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 11, изображение 2 из 2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
  12. iPhone 4 Verizon Home Button Replacement, Rear Camera: шаг 12, изображение 1 из 1
    • Remove the following five screws:
    • Three 1.3 mm Phillips screws
    • One 1.5 mm Phillips screw
    • One 2.4 mm Phillips screw
    Careful here...On my phone, the little mounting screw boss (the part the screw threads into) of the top red-circled screw came unglued/welded from the underlying board, meaning the screw will no longer be able to be screwed back in.
    usnmustanger - Ответить
    The three 1.3 mm screws are very difficult to distinguish from the 1.5 mm screw. I spent a long time with a magnifying glass trying to tell them apart. For the other steps of the repair, I kept the screws in a tray compartment along with the piece that they connected, but for this step I recommend keeping each of the different types of screws separate.
    One of the 1.3 screws stripped on the head. Any idea how to remove it? I got the other screws out.
    kayers - Ответить
    Haven't gotten to the screws yet. Saw this, read it, knew from class to use bathroom tiny white cups marked sizes of screws. Thank you so much for color coding diagram and point bullets.
    Teresa - Ответить
  13. iPhone 4 Verizon Home Button Replacement: шаг 13, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 13, изображение 2 из 2
    • Lift the cable cover from its edge nearest the top of the iPhone.
    • Pull the cable cover tabs out of their slots cut into the EMI shield on the logic board and remove it from the iPhone.
  14. iPhone 4 Verizon Home Button Replacement: шаг 14, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 14, изображение 2 из 2
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
    Better to delay removing the camera and its cable until the Display and Digitizer cables are removed as there is an arm on the right side of the camera that slips under the other cables.
    ed50buffalo - Ответить
    I agree with ed -- move the camera removal step until after Step 16, after the digitizer and display cables have been removed, as there is a tab/arm on the camera's cable that should go under these two cables during reassembly.
    Chris Kovach -
    I found it quite easy to remove the camera at this step. Just simply move the camera up and slip it to the left in order for the arm/tab to come out.
    Kent - Ответить
    When putting the camera back in, make sure the tab on the right goes under the display and digitizer cables.
    Calion - Ответить
  15. iPhone 4 Verizon Home Button Replacement, Logic Board: шаг 15, изображение 1 из 1
    • Disconnect the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Power button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
    The Digitizer Cable on the new display seems to be too short. Trying to make it reach. It doesn't reach its place on the logic board. Going to disassemble and start over. (Step 15)
    Any pointers?
    chris - Ответить
    What happened was there is a tab on the cable, and that didn't go all the way through the casing. I made this mistake about 3 times. It's not too short, just move the screen a little away from the casing, and pull the cable all the way through without ripping it.
    savage24x -
    ⚠️ On reassembly, before plugging in the screen/digitizer cables, put the rear facing camera back in. There's a prong on the camera that lays underneath them.
    I Can't Even - Ответить
  16. iPhone 4 Verizon Home Button Replacement: шаг 16, изображение 1 из 1
    • Remove the 1.5 mm Phillips #000 screw near the headphone jack.
    The two verizon phones I've repaired so far both have a phillips screw that screws into the flathead screw that is shown here. The grounding clip is between the phillips and the flathead. So remove the phillips, and then the grounding clip, that will reveal the flathead screw.
    boo - Ответить
    take out screw on top of stand of first, then take of grounding plat, and then stand off.
    Corey Berghorst - Ответить
    This is correct.
    savage24x -
    Echoing the notes from 'boo' and Corey -- that's exactly what I saw too. Perhaps the guide should be updated?
    This has been changed several times on the iphone 4 logic board manual, and the changes are always being reverted. There _IS_ a screw in step 16, but someone seems intent on not having it mentioned in the manual. Dunno why...
    Mobile Rapid Response Unit - Ответить
    Because it's mentioned in Step 20.
    usnmustanger -
    It may have been mentioned in step 20 at some point, but it isn't anymore. The phillips head screw that's mentioned in step 20 is the one holding the grounding finger to the rear-facing camera corner of the motherboard.
    That said, my concerns about step 16 have since been rectified, so I suppose step 20 could've been fixed at the same time.
    The manual does need to be updated for the screw being inside the standoff screw.
    Billy - Ответить
    Some Phones such as mine (march2012) had a philips head screw here..
    Anson - Ответить
    There's a little rubber piece that you can see in the Step 17 & Step 21 pictures just above the yellow sticker. It fits over the edge of the board where the two ribbon cables from the display/digitizer come up through the board (Step 36). It's there to make sure the ribbon cables don't rub against the sharp edge of the board. This piece loves to fall out when pulling the logic board off. Make sure to put it back in when routing the cables in Step 36, thin edge on the bottom, thicker edge on the top.
    Jere - Ответить
  17. iPhone 4 Verizon Home Button Replacement: шаг 17, изображение 1 из 1
    • Lift the small grounding clip up off the logic board and remove it from the iPhone.
    one of the small prongs on the standoff near the headphone jack broke off, is this a big deal or should i not worry about it
    Sam - Ответить
    Don't worry about it, the stand-off just holds the wifi antenna in place
    Jake -
    Can you show how this piece attaches?
    Mitch Frederick - Ответить
    This piece broke when i had to drill out stripped screw. Is it important enough to replace it?
    Buhz - Ответить
    hey okay so i did all the step and my i phone screen wont work and know the power button
    wont work ether help
    Apolonia - Ответить
  18. iPhone 4 Verizon Home Button Replacement: шаг 18, изображение 1 из 1
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
    • When reconnecting the wifi ribbon connector to the mother board be VERY certain that the round connector at the end of the ribbon cable is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connection.
    For me, aligning the connector when putting things back together was the most difficult part of this repair. Unlike reattachment of the radio antenna in step 11, it is very difficult to see whether the male/female are aligned properly before applying pressure. Unfortunately, I have no secret as to how to accomplish this, other than to say that my WiFi is working after the repair.
  19. iPhone 4 Verizon Home Button Replacement: шаг 19, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 19, изображение 2 из 2
    • If present, remove the piece of tape covering a Phillips screw near the power button.
  20. iPhone 4 Verizon Home Button Replacement: шаг 20, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Standoff Screwdriver for iPhones
    $5.49
    Купить
    • Remove the 2.5 mm Phillips #000 screw securing the logic board near the power button.
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    can someone tell me what that flap thing is thats right behind the other? also whats its use & how important it is. ( the one thats hidden behind the other)
    Camarri - Ответить
    Now is a good time to remove the gold grounding finger. I used the condiments cups from Wendy's (fast food restaurant) to hold my screws for each step. Hope this helps.
    Kent - Ответить
    I’d use a Phillips 00 instead of a flathead
    Zach Heaton - Ответить
  21. iPhone 4 Verizon Home Button Replacement: шаг 21, изображение 1 из 1
    • Remove the 3.4 mm Phillips screw near the vibrator motor.
    • Remove the two 3.6 mm standoff screws along the side of the logic board nearest the battery opening.
    When replacing the standoff screw closest to the dock connector, make sure it is tightened all the way down. The battery terminal screw fits in the standoff later, and if the standoff isn't tight (NOT TOO TIGHT!) then the battery will not be completely connected and your phone will power off unless tethered. This mimics a bad logic board symptom! Inspect this before replacing your logic board!
    goodski - Ответить
    The standoff screws are very difficult to get out unless you have a very tiny (jeweler's) flathead screwdriver, which I lacked. A pocketknife did work, however.
    Calion - Ответить
  22. iPhone 4 Verizon Home Button Replacement: шаг 22, изображение 1 из 1
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There's a small rectangular rubber pad at the top of the logic board that prevents the display cables from chafing against the edge of the board. If it comes loose during your repair, make sure to position it correctly when reinstalling your logic board.
    When I was attempting to reinstall the logic board (step 21 in reverse), a small rubber bumper came loose from 'somewhere' on the board (I think). It isn't visible in any of the photos, so I really have no idea where it came from!
    I don't see it in the pictures either, but I'm pretty sure there is a black bumper that rides on the 'top' of the logic board. I believe it reduces friction between the display/digitizer cables and the top of the logic board.
    Ken McCann -
    You can see this "bumper" in steps 16 and 20 (right above the yellow sticker in the pics), and it provides relief for the digitizer and display cables as they both come up and around the edge of the logic board. I put my bumper with its thicker side down towards the inside of the phone and it worked fine.
    Chris Kovach -
    This is correct, and if you look closely the rubber piece has a "thick" and "thin" side. The "thin" side should be facing "up" on logic board (towards back cover) while the "thick" is pointed "down" (towards screen)
    Joe - Ответить
    The rubber bumper has a groove in it, which rides a notch along the top edge of the logic board. Its purpose is to ease pressure between the top of the phone and the board. If you look at the top of the frame, there is a little horizontal ridge about 0.8cm (3/8") long which is just the right width of the rubber bumper.
    For reference:
    http://i.imgur.com/GITTv.jpg
    http://i.imgur.com/IoeZV.jpg
    http://i.imgur.com/Po9h8.jpg
    TheIronGiant - Ответить
    Your images show incorrect placement of the rubber spacer. Step 20 shows correct placement. It is just above the scan code sticker on the motherboard. That is where the ribbon cables roll over, so it makes sense.
    I assume the thick side would be facing the rear of the phone, but can not be sure.?
    http://d3nevzfk7ii3be.cloudfront.net/igi...
    Keil Miller -
    I wouldn't use Windex. It's mostly water. Why would anyone put water on a connection? Use isopropyl alcohol and be certain that it's at least 95% alcohol.
    Better yet use contact cleaner or the original Brakleen (in the RED can). You can find the Brakleen at any automotive store.
    Tom Brandolini - Ответить
    I am having major issues with the motherboard! I have removed all the screws and done all the necessary steps, but the motherboard won't budge! It will not move at all! Help!
    kcmonstr - Ответить
    Never mind! I got it! It was like screw inception O.O
    kcmonstr -
    I experienced that when the rubber spacer had the thick side up towards the rear of the phone, the display data cable would plug in but had enough pressure from the rubber bumper pushing up that it would eventually become partially unplugged. This may not be immediately apparent while putting the phone back together because of still being partially plugged in. This was not an issue when the thin side was installed facing up towards the back of the phone.
    uncletom - Ответить
  23. iPhone 4 Verizon Home Button Replacement: шаг 23, изображение 1 из 1
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button.
    Hope someone can ease my uncertainty: does the grounding finger for the
    rear-facing camera go on TOP of the motherboard OR between the motherboard and
    the standoff???
    Under. There is nothing to ground if it went over the pcb. Look on the backside.
    Keil Miller -
    It shouldn't matter. If on top, it will still be grounded through the screw. I've done both without any problems.
    Anthony - Ответить
    What happens if you accidentally lose this piece or when putting it back together it shoots somewhere
    Jen - Ответить
    i didn’t see that thing when i removed the camera
    meow - Ответить
  24. iPhone 4 Verizon Home Button Replacement, Vibrator: шаг 24, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement, Vibrator: шаг 24, изображение 2 из 2
    • Use the edge of a plastic opening tool to pry the vibrator off the adhesive securing it to the frame of the iPhone.
    • Remove the vibrator.
    For the record.... This thing was really REALLY stuck with adhesive when I removed it. Surprised I am the first to comment on this.
    kevindelong - Ответить
    Make sure to align the hole on the vibrator to the hole on the frame for the screw that will attach the logic board.
    uncletom - Ответить
  25. iPhone 4 Verizon Home Button Replacement, Screen: шаг 25, изображение 1 из 1
    • Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
  26. iPhone 4 Verizon Home Button Replacement: шаг 26, изображение 1 из 1
    • Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
    My plastic corner bracket actually came out with the screw, so be aware this can happen
  27. iPhone 4 Verizon Home Button Replacement: шаг 27, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 27, изображение 2 из 2
    • Remove the speaker enclosure assembly from the iPhone.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
    Be careful not to lose the black plastic triangle spacer (roughly the same shape as the one you removed in step 25, just thicker). This spacer can be seen in the first picture (step 26) in the lower left hand corner near the palm. It goes under the metal.
    Steven K - Ответить
    I can't find where the wifi grounding fingers go when reassembling. The picture isn't very helpful. Any ideas?
    otonomurray - Ответить
    These Wi-Fi grounding fingers should be distinguished in the image that accompanies the instructions to show their location to ensure their identification to be cleaned and to be in the proper position upon reassembly. If I guess correctly, there is one by the screw on the left, two below the thumbnail in the image and a fourth that is blocked from view in the image by the logic board.
    uncletom - Ответить
  28. iPhone 4 Verizon Home Button Replacement: шаг 28, изображение 1 из 1
    • Remove the small pieces of black tape covering the display mounting tabs.
  29. iPhone 4 Verizon Home Button Replacement: шаг 29, изображение 1 из 1
    • Remove the 1.6 mm Phillips screw securing the display assembly near the power button.
    This isn't particularly easy. Maybe it's the screwdriver I have, but I can't seem to reach these corner screws.
    Andrew Ruiz - Ответить
    No the problem is that you should probably remove the audio Jack. There is NO way you can unscrew that screw without stripping it without taking the audio jack out.
    futballlover44 - Ответить
  30. iPhone 4 Verizon Home Button Replacement: шаг 30, изображение 1 из 1
    • Remove the 1.6 mm Phillips screw near the headphone jack.
    Nearly impossible to reinstall this screw when reassembling.
    joeboo7902896 - Ответить
    I was able to perform this step on my first repair attempt. Here's a tip: the rounded part of the headphone cable is very stiff and "spring" like. Just take a very thin Philips (#000) screwdriver and lay it down on the cable diagonally, pointing almost directly towards the screw. Push gently down on the cable and it will cave in somewhat. This is fine. Then you can go straight in at the screw and turn it out.
    Photograph: http://i.imgur.com/wKigI.jpg
    Thank you Bradley. I've had tons of grief with this screw in the past. I've just had to turn the driver at an angle and curse and yell and retry it 5 times before it worked. This is a MUCH better approach! I had no idea that cable safely had that much give. You have my gratitude.
    Kyle Sankowicz - Ответить
    Took me an hour to get this screw back in. Tried different tools. I didn't have a long shank thin phillips head magnetic screwdriver. That would have helped out tremendously.
    DC1 - Ответить
    AH, perhaps I jinxed myself, but I could not get this screw out. I think I stripped the phillips head too. Is there anything left to do to salvage it?
    Linda Vanasupa - Ответить
    This screw was very hard to replace - lost the part after many minutes of trying.
    tponeill3 - Ответить
    I was just able to replace this screw by first placing it in the hole with tweezers, then using the Phillips head screwdriver at an angle. The screw itself is slightly magnetized, and held onto the edge of my tweezer point, and then held itself inside the hole.
    jzeth - Ответить
    It's kind of frustrating that this guide doesn't include an optional headphone jack removal step or something, as I can't even do what Bradley suggested. I have the ifixit pro kit and the thin section of the shank on the bit isn't long enough to reach without removing it.
    If needed, you can find instructions for removing the headphone jack here.
    Jeff Suovanen -
    i succeeded putting the screw back in by putting the screw into a piece of cellophane plastic and holding it in place with it until it started and then pulling out the cellophane once it was.
    ayon3rd - Ответить
  31. iPhone 4 Verizon Home Button Replacement: шаг 31, изображение 1 из 1
    • Remove the 1.6 mm Phillips screw near the lower microphone.
  32. iPhone 4 Verizon Home Button Replacement: шаг 32, изображение 1 из 1
    • Remove the 1.6 mm Phillips screw near the dock connector cable.
    I stripped this screw. Any suggestions on how to get it out?
    Aaron Shapiro - Ответить
  33. iPhone 4 Verizon Home Button Replacement: шаг 33, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 33, изображение 2 из 2
    • Loosen the three large-headed Phillips screws along the volume button side of the iPhone about one half turn.
    • It is not necessary to completely remove these screws. When reinstalling the display assembly, be sure the washers are closest to the screw head (as seen in the second picture).
    These screws are impossible to remove. Please help, what's the trick. I only could get one of them to loosen
    Dana Palermo - Ответить
    Someone please help, I'm going to throw this thing across the room. cannot get these screws to loosen
    Dana Palermo -
    You need a smaller screwdriver. One in my kit was too big spinning out the heads. Can also touch each screw with soldering iron if locktite is holding it but probably driver as they all came with the right driver.
    curvecrazy - Ответить
  34. iPhone 4 Verizon Home Button Replacement: шаг 34, изображение 1 из 1
    • Loosen the three large-headed Phillips screws along the other side of the iPhone about one half turn.
    I found removing the three screws on one side during reassembly made it easier to keep the washers on the opposite side in the correct position when installing the display. When the display is in place, reinstall the three screws and then snug down all six. Then back all off about a quarter to a half turn to assist in aligning the holes for the four corner screws. Only after all ten screws are in place should the screws be tightened. Be sure to gently squeeze the display down to the outer frame at each screw while tightening to eliminate any gaps between the two.
    uncletom - Ответить
    That one corner screw is at the wrong angle what a pain stripping out the head of my driver/screw!
  35. iPhone 4 Verizon Home Button Replacement: шаг 35, изображение 1 из 3 iPhone 4 Verizon Home Button Replacement: шаг 35, изображение 2 из 3 iPhone 4 Verizon Home Button Replacement: шаг 35, изображение 3 из 3
    • Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
    • Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the home button cable may tear.
    • De-route the digitizer and LCD cables through the steel inner frame.
    • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
    • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
    • If the digitizer cable has been installed incorrectly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
    • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
    Remember to take the earpiece screen off the old lcd and put it on the new screen. Most replacements do not include this mesh screen.
    boo - Ответить
    DEFINITELY REMEMBER THE ABOVE ADVICE TO TRANSFER THE METAL MESH SCREEN FROM THE OLD SCREEN TO THE NEW ONE.
    I've done this twice now, and it really, really stinks because you don't usually see it until the phone is all back together. That would mean doing the whole process again. Slapped myself in the forehead the second time.
    Thank you so much for this easy to follow guide, but it's so good I don't usually look at the comments. Maybe this last little thing could be added.
    Either way, Thanks Again.
    isaacstuff - Ответить
    took me about 2 hours to succesfully complete the entirety of this replacement. Although the hardest part is putting the screws back into their respective holes. And it does help to read the comments after reviewing the guide as well. It wasn't until I had the customer's phone completely back together that I realized that earpiece grill wasn't there on the new screen.. nevertheless.. Thank You to my favorite repair website for the easy to follow guides.
    Chris - Ответить
    There is also a small plastic ring around the front-facing camera that may come away with the broken screen. Make sure to recover it and re-attached to the camera before reassembly.
    Mark - Ответить
    Well I got about 1/2 way back through the re-assembly and found that the digitizer cable was too short. I disassembled back to here and this time started snapping the new display surface back into place beginning at the end where the digitizer cable feeds through. Then I did a "dry-run" with the logic board to ensure the cable reaches and it looks good.
    Instruction here refers to routing the digitizer/LCD cables through the
    "outer case". Just for the sake of clarity,
    isn't the part through which the ribbons are
    being routed the FRAME? If it really IS the outer case, where is the "inner case"?
    To Mark and the small plastic ring, I remembered to salvage it an save it, but then forgot to reinstall it... Oops... Humm.. Wonder if the phone really needs it? .......
    Chenoa14 - Ответить
    ive gotten everything apart and all of the screws out.. but cannot seem to pry the screen off. suggestions?
    Rachael - Ответить
    The digitizer/LCD cable warning is VERY important! I thought I had it right, but had to go back and disassemble again when I realized the digitizer connection wouldn't meet - it had folded under the frame (which I might have noticed if I'd compared it to the photo in Step 23 - that clearly shows that the 2 cables should be about the same length).
    It's a great manual, and a satisfying repair - this iPhone had been run over, the front glass totally shattered, and now it's operational!
    Jen Morris - Ответить
    Got my phone back together and cut it on and the screen is white with a couple pixels in upper left hand corner that are black. I could very faintly make out the screen after it booted up and was able to power it down. Any recommendations on how to proceed. I plan to disassemble and check all the connections.
    Doug - Ответить
    Same problem as Rachael. I've removed all the screws but the front glass isn't budging despite my spudging. Any tricks for resolving this? I don't want to break it at this point.
    Dave - Ответить
    Use the guitar pick or a fingernail file to pry up one of the corners (the plastic goes with the glass away from the metal frame). Then carefully pull up the whole screen. There are plastic "feet" that are holding the screen on, you'll have to pry up an edge to get them to let go.
    rafesmom -
    I had a lot of broken glass stuck to the adhesive after removing the screen. Be sure you use tweezers and a scraper (be careful) to remove all the old debris prior to installing the new part. I got my part from ifixit so it had the mesh and the ring for the camera on the new part.
    During the whole replacement of everything process, I ripped off the cable for the digitizer from the main cable, is there any way to repair this or should I just order a new screen?
    Dylan Carter - Ответить
    Reassembly Warning: Be careful routing the cables through the frame. The digitizer cable tears easily. The LCD cable has the square shield. So, the digitizer cable is the cable without the shield. On the digitizer cable there is a section where the cable is wide then it gets more narrow. Where it tapers down (gets narrow) the cable can tear at this point. If the digitizer cable is torn the touch screen feature will not work.
    scottrape - Ответить
    There's adhesive top and bottom which gave me a large struggle spooning off the screen. My LCD cable was short due to it folding take it apart again uggg
    The warning regarding tearing of the cable cannot be overemphasized. I tore a brand new cable on installation and had to hang my head in shame after having to reinstall a broken screen until I got another new part.
    Graeme Hatley - Ответить
    It’s best to put the plastic ring around the lens before assembly. The assembly I got from ifixit had the ring oriented wrong and interfered with the glass laying flush. I removed it with a drop of alcohol and rotated it around the lens until it slid in flush.
    Take out the 6 side screws/washers. Put the four corner screws in loose and then thread in the 6 screws/washers. Once all are threaded in then tighten. It’ll save you a lot of grief.
    Sue Lucas - Ответить
  36. iPhone 4 Verizon Home Button Replacement: шаг 36, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement: шаг 36, изображение 2 из 2
    • Remove the display assembly from the iPhone.
    • Be sure to separate the home button from the front panel. If the home button sticks to the front panel you may tear the home button cable.
    • When replacing the display assembly, note the following:
    • You may have to reuse the earpiece grille and the clear plastic ring around the front facing camera from the old/damaged assembly. This will depend on where you buy the replacement part.
    • Your replacement display may come with colored plastic film on the back of the LCD. If so, use the pull tab near the home button to peel the plastic film from the LCD before installing the new display in your iPhone.
    • After reassembly, note the following:
    • Clean the touchscreen surface with an alcohol wipe prior to turning the iPhone back on. The alcohol helps dissipate any lingering static electricity, which can cause problems with the display.
    • After reassembly, connect the iPhone to an AC power source before turning it on for the first time. Once the iPhone has booted up successfully, you can disconnect the AC power.
    Nope. Broke the Home button cable at this point, because the button stuck to the display during separation.
    Chris - Ответить
    When I put it all bck together the phone itself comes on but the screen won't come on... did I do something wrong?
    blake88rob - Ответить
  37. iPhone 4 Verizon Home Button Replacement, Home Button: шаг 37, изображение 1 из 2 iPhone 4 Verizon Home Button Replacement, Home Button: шаг 37, изображение 2 из 2
    • Use a clean fingernail or the edge of a plastic opening tool to flip up the retaining flap on the home button ribbon cable.
    • Be sure you are prying up on the hinged flap, not the socket itself.
    The plastic tool is too large and cumbersome. I just destroyed the connector. Now What!
    sbrescia100 - Ответить
  38. iPhone 4 Verizon Home Button Replacement: шаг 38, изображение 1 из 1
    • Use a pair of tweezers to pull the home button cable out of its socket.
    The socket came off with cable. There's no indaction it was glued on, and it fits up like a puzzle piece. What do I do now?
    Amy - Ответить
  39. iPhone 4 Verizon Home Button Replacement: шаг 39, изображение 1 из 1
    • Carefully de-route the home button cable through its slot in the outer case and remove it from the iPhone.
    There is no mention as to what to do with the rubber gasket that was adhered to the front panel. If I leave it as it is, it obscures the button function in the aperture. It's not obvious, so I guess I'm leaving it out.
    xtophr - Ответить
Заключение
129 участников успешно повторили данное руководство.
3 Комментариев
How can a company that prides itself on simplicity and elegance make something so needlessly unserviceable? I don't mind the small screws, even if I wonder how many of them really need to be there... but the fragile cables, little black spacers, the pentalobe screws and the glue - oh the inhumanity of the glue! The only thing that makes me happy is, now that Tim Cook's decided that they're going to service these things in-store, the thought of Apple employees sending an earful of expletives up the management chain.
jwkc2 - Ответить
Small and fragile = lite weight. And all of those spacers and glue is to keep everything in place and prevent those small and fragile parts from breaking as you use the phone. If you want a tiny, lite phone there are compromises. And Apple's mantra has never been serviceability. It's about getting you to upgrade to the new cool thing every 1-2 years, way before the phone would normally need servicing. And the Apple store really only services new batteries and screens. For pretty much everything else they just give you a new phone.
J V -
is there a way to remove the button without replacing the cable?
Crystal Haugh - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 26
За всё время: 55,218
