Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
Инструмент, используемый на этом этапе:iSclack$24.99
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
Use the edge of a spudger to slice through the adhesive on either side of the phone.
Remove the following screws from the battery connector bracket:
One 3.0 mm Phillips #00 screw
One 2.3 mm Phillips #00 screw
Use the flat end of a spudger to disconnect the battery connector from the logic board.
Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
Slowly and gently pull the two strips up and away from the phone.
The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
75 человек успешно провели ремонт по этому руководству.
11 Комментариев
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
