iPod 2nd Generation Display Replacement
Выберете то, что вам нужно
    1. iPod 2nd Generation Display Replacement, Rear Panel: шаг 1, изображение 1 из 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod 2nd Generation Display Replacement: шаг 2, изображение 1 из 1
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Спросите у FixBot
    3. iPod 2nd Generation Display Replacement: шаг 3, изображение 1 из 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Спросите у FixBot
    4. iPod 2nd Generation Display Replacement: шаг 4, изображение 1 из 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Спросите у FixBot
    5. iPod 2nd Generation Display Replacement: шаг 5, изображение 1 из 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      Спросите у FixBot
    6. iPod 2nd Generation Display Replacement: шаг 6, изображение 1 из 1
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      Спросите у FixBot
    1. iPod 2nd Generation Display Replacement, Hard Drive: шаг 7, изображение 1 из 1
      • Peel up the metallic tape attached to the top of the battery.
      Спросите у FixBot
    2. iPod 2nd Generation Display Replacement: шаг 8, изображение 1 из 1
      • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
      Спросите у FixBot
    3. iPod 2nd Generation Display Replacement: шаг 9, изображение 1 из 1
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      Спросите у FixBot
    1. iPod 2nd Generation Display Replacement, Hard Drive Cable: шаг 10, изображение 1 из 1
      • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
      • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
      Спросите у FixBot
    2. iPod 2nd Generation Display Replacement: шаг 11, изображение 1 из 1
      • Slide the hard drive cable out of its connector.
      Спросите у FixBot
    1. iPod 2nd Generation Display Replacement, Display: шаг 12, изображение 1 из 1
      • Lift the blue hard drive mounting bracket out of the iPod.
      Спросите у FixBot
    2. iPod 2nd Generation Display Replacement: шаг 13, изображение 1 из 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Спросите у FixBot
    3. iPod 2nd Generation Display Replacement: шаг 14, изображение 1 из 1
      • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
      • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
      Спросите у FixBot
    4. iPod 2nd Generation Display Replacement: шаг 15, изображение 1 из 1
      • Remove the 8 T6 Torx screws from the logic board.
      Спросите у FixBot
    5. iPod 2nd Generation Display Replacement: шаг 16, изображение 1 из 1
      • Lift the logic board up enough to disconnect the orange touch wheel cable.
      • Lift the logic board out of the iPod.
      Спросите у FixBot
    6. iPod 2nd Generation Display Replacement: шаг 17, изображение 1 из 1
      • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
      Спросите у FixBot
    7. iPod 2nd Generation Display Replacement: шаг 18, изображение 1 из 1
      • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
      Спросите у FixBot
    8. iPod 2nd Generation Display Replacement: шаг 19, изображение 1 из 1
      • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
      • Lift the display off the logic board.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 635 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 59
За всё время: 8,401
