Введение
This is an easy way to quickly replace the side wheel of your Roomba. It is slightly more work than the front wheel, which can be found here, but is a straightforward process.
Выберете то, что вам нужно
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver.
4 человек успешно провели ремонт по этому руководству.
