iRobot Roomba 560 Fan Replacement
Выберете то, что вам нужно
  1. iRobot Roomba 560 Fan Replacement, Fan: шаг 1, изображение 1 из 1
    • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
    Спросите у FixBot
  2. iRobot Roomba 560 Fan Replacement: шаг 2, изображение 1 из 2 iRobot Roomba 560 Fan Replacement: шаг 2, изображение 2 из 2
    • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
    • Remove the top of the vacuum bin by pulling it straight up.
    • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
    Спросите у FixBot
  3. iRobot Roomba 560 Fan Replacement: шаг 3, изображение 1 из 3 iRobot Roomba 560 Fan Replacement: шаг 3, изображение 2 из 3 iRobot Roomba 560 Fan Replacement: шаг 3, изображение 3 из 3
    • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
    • Remove the casing that surrounds the fan by pulling it straight up.
    • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
    Спросите у FixBot
  4. iRobot Roomba 560 Fan Replacement: шаг 4, изображение 1 из 3 iRobot Roomba 560 Fan Replacement: шаг 4, изображение 2 из 3 iRobot Roomba 560 Fan Replacement: шаг 4, изображение 3 из 3
    • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
    • Remove the casing from the fan and battery component by pulling it straight up.
    Спросите у FixBot
  5. iRobot Roomba 560 Fan Replacement: шаг 5, изображение 1 из 1
    • Remove the small black button from the top of the battery.
    • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
TJ Tamura
Участник с: 10/01/15
289 Репутация
1 руководство автора
Команда
Cal Poly, Team 1-22, Maness Fall 2015 Участник Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 членов
Автор 14 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 87
За всё время: 5,176
