Введение
Use this guide to replace an Edge-Sweeping Brush in your Roomba vacuum robot.
Выберете то, что вам нужно
Make sure your Roomba is turned off and flip it over to access its underside.
Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
Use your fingers to gather all three brush arms and grab them simultaneously.
Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
