Введение
Use this guide to replace the Corner Brush Module on your iRobot Roomba S9+ (Model number: s955020). Be sure to be careful when you’re disconnecting wires. Only pull on solid plastic pieces and not wires. For more information, check out our troubleshooting page.
Выберете то, что вам нужно
Place your Roomba upside down with the brush module facing you.
Push the grey tab by the top left corner of the brushes to release the retaining arm.
Flip over the brush module to access the corner brush motor.
Unscrew the 15mm Phillips #0 screws holding the motor in place.
2 участников успешно повторили данное руководство.
2 Комментариев
Wish there was a way to replace that plastic. Stripped on mine.
