Введение
This guide will teach someone how to access and remove the screen display of their iRulu AX760. In following this guide you will learn how disconnect and replace the screen display.
Выберете то, что вам нужно
Use a plastic opening tool or metal spudger to free the rear cover.
Insert your spudger into the side of your tablet.
Crack open each edge and remove the cover.
Take your plastic flat head tool and insert it under the battery.
Lift the battery up.
Make sure to remove any tape from the battery.
Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
Keep the wires of the battery taught.
The iron should only be pressed to the solder for 2-3 seconds max.
Visit this link for information about soldering. How To Solder and Desolder Connections
Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
You must desolder several sets of contacts before attempting to remove the motherboard.
You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
You will not need a metal spudger in order to re-place the motherboard
Remove the plastic peel attached to the back of the screen display.
Continue lifting the screen by hand and pull it out until it is completely removed.
Еще один человек закончил это руководство.
