Отремонтируйте ваше устройство
Обучение ремонту
Магазин
MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • 360°
360
209,99 $
209,99 $
Спецификации
Описание
Описание
Replace the 2.4 GHz logic board in your MacBook Pro 13" Unibody (Mid 2010) laptop and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Совместимость
Совместимость
  • MacBook Pro 13" Unibody A1278 Mid 2010
Характеристики
Характеристики
Part #:
661-5559
Model #:
A1278
Speed:
2.4 GHz
GPU:
NVIDIA GeForce 320M
Совместимость
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
Истории ремонта
Фото профиля
Моя проблема
My MacBook Pro was suffering from the same Graphics problem as many others have experienced.
Моё решение
I followed the instructions to take out the faulty Logic Board. Then I installed the replacement from iFixIt, with a little bit of thermal paste. Got it all screwed back together and was done in 25 Minutes. . . .
Фото профиля
Моя проблема
The logic board failed due to my daughter spilling milk on it. I tried to clean the board but the lactic acid managed to eat away some of the thin traces.
Моё решение
I ordered a replacement from iFixIt, removed the old board and installed the new one. The system booted and everything worked as expected. So f . . .
Фото профиля
Моя проблема
My computer’s logic board stopped working, needed to be replaced.
Моё решение
The repair was actually pretty easy and I felt proud of myself for the repair... and thankful for iFix :)
Мой совет
Always be curious (but cautious)! There’s so many things you can do on your own and save money if you take the time to researc . . .
Фото профиля
Моя проблема
Broken RAM sloth, so the MacBook was working a bit slow.
Моё решение
It went very well. The guide I used was very helpful and made the repair very easy! :)
Мой совет
If you just follow the guide everything goes smoothly! :)
Фото профиля
Моя проблема
A few weeks ago my Macbook Pro started malfunctioning and gave me a blank white screen with a flashing folder and a question mark. I was unsure what this was and after some online research I figured it may be my hard drive. I installed a new hard drive but my Mac wouldn’t see it after going into r . . .
Фото профиля
Моя проблема
One drop or water got to the logic board
Моё решение
simple replacement
Мой совет
keep Mac away from ANY source of moisture
Показать еще
