Моя проблема
Had a cracked corner for the last 2 years and the battery was taking 6 hours to charge and lasted only 8-10 hours.
Моё решение
The repair went great, the instructions were easy to follow, no issues at all.
Мой совет
People should not expect the screen to have the same depth of color, richness, or fullness of their original screen, everything is a bit lighter in color with the replacement. Also, I'm assuming this is a defect in the replacement screen I received, but there is a small area above the home button that has distorted pixels, like when you press on an LCD screen and you get ghosting, but this ghosting doesn't go away. It's a bit hard to see in the pics posted, but if you look close you can see it. And no, they do not show up in a screenshot, there is a mechanical issue with the screen.
0 Комментариев
