Введение
A simple look into the Universal Dock
Need a flat nose screw driver 2.4mm
philip screw driver #1
Выберете то, что вам нужно
Pry along the edge of the bottom of the case. It will just pop out.
There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Один комментарий
Can the actual dock insert (the section the iPod would clot on top of) be used in an Apple iPod HiFi repair? (see repair article Apple iPod Hi-Fi iPod Dock Inserts Replacement)
