Введение
Belkin WeMo Switch teardown.
Выберете то, что вам нужно
Model: F7C027
FCC ID: K7SF7C027
Input: 120 V, 15 A, 60 Hz
Output: 120V, 15 A, 60 Hz
Remove the four 11.9 mm triangle screws securing the two halves of the case together.
Remove the two 9.9 mm Phillips #1 screws securing the power board to the device.
Use the flat end of spudger to gently pry the retaining flaps away from the motherboard.
The motherboard should now come free.
Components on the motherboard:
Ralink RT5350 Wi-Fi SoC
Winbond W9825G6JH-6 256 Mb 166 MHz SDRAM
Macronix MX25L12835EMI-10G 128 Mb NOR Flash Memory
Momentary push button switch for factory reset
Momentary push button switch for power switch
4 Комментариев
I notice that’s a 240V 10amp relay they’ve used. Do you think there is any electrical difference (aside from the plug pattern) between the US 110V version and the EU/Australian 220V one?
Thanks, also here 2 of them after little use: The exterior on off button had come loose and was rattling around inside. Very poor quality now I have opened them. Guess need to try and glue them back on.
