ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Ρ‹Π±Π΅Ρ€Π΅Ρ‚Π΅ Ρ‚ΠΎ, Ρ‡Ρ‚ΠΎ Π²Π°ΠΌ Π½ΡƒΠΆΠ½ΠΎ
Π­Ρ‚ΠΎ Π΄Π΅ΠΌΠΎΠ½Ρ‚Π°ΠΆ Π° нСруководство ΠΏΠΎ Ρ€Π΅ΠΌΠΎΠ½Ρ‚Ρƒ. Π§Ρ‚ΠΎΠ±Ρ‹ ΠΎΡ‚Ρ€Π΅ΠΌΠΎΠ½Ρ‚ΠΈΡ€ΠΎΠ²Π°Ρ‚ΡŒ Canon PowerShot S500, Π²ΠΎΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠΉΡ‚Π΅ΡΡŒ нашим сСрвисным руководством.
  1. Canon PowerShot S500 Teardown, Canon PowerShot S500 Teardown: шаг 1, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown, Canon PowerShot S500 Teardown: шаг 1, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Here are all the components of my disassembled Canon PowerShot S500, excluding the battery and screws.
    • The second photo show what the camera looks like before (and hopefully again after!) repair. (yes, I was able to put it all back together again!)
    • Follow along to see how to take apart and repair this camera, and to see what's inside...
  2. Canon PowerShot S500 Teardown: шаг 2, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 3 Canon PowerShot S500 Teardown: шаг 2, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 3 Canon PowerShot S500 Teardown: шаг 2, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 3 ΠΈΠ· 3
    • Using a small Phillips screwdriver, remove the screw on the top right of the back of the camera.
    • Remove the 4 screws on the bottom of the camera near the tripod socket
    • Remove 2 screws on the side with the USB connector cover (one of the screws is underneath the cover)
  3. Canon PowerShot S500 Teardown: шаг 3, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 3, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • On the other side of the camera, remove the 4 screws near the wrist strap mounting lug.
    • Remove the small metal plate. This will also free the Compact Flash door.
  4. Canon PowerShot S500 Teardown: шаг 4, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 4, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • You can now remove both the front and rear shells of the camera body
    • Thank goodness the camera body is held together by screws for easy disassembly! Many other Canon PowerShot cameras are constructed similarly.
  5. Canon PowerShot S500 Teardown: шаг 5, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • There's a small loose black plastic piece in the space beside the flash. At first it dropped out and I didn't notice where it came from!
    • Remove the plastic piece, noting where to re-install it later
  6. Canon PowerShot S500 Teardown: шаг 6, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here is the back of the camera without the shell. You can see the switch contacts on the flex circuit along the bottom. They're attached to the small metal plate that we'll remove in the next step...
  7. Canon PowerShot S500 Teardown: шаг 7, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 7, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Remove the screw on the bottom plate. While we're at it, there are 2 screws on the side near here (2 circles at left). They hold the tripod socket to the side frame.
    • With the 3 screws removed, you can now gently lift off the bottom metal plate.
  8. Canon PowerShot S500 Teardown: шаг 8, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here's the bottom plate removed. There's still a flat ribbon cable connecting it to the camera...
    • You can see a small black microswitch on the right end of the metal plate. The switch detects whether the battery door is closed or open.
  9. Canon PowerShot S500 Teardown: шаг 9, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 9, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • ... gently flip up the black catch at the edge of the ribbon cable connector. You can now pull the ribbbon cable out of the connector.
    • In the 2nd photo, you can see the bottom plate, along with rear button switches, and battery door microswitch.
    • Note: there is still a clear plastic insulating sheet attached between this assembly and the camera. It will be detached at a later step.
  10. Canon PowerShot S500 Teardown: шаг 10, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Remove the screw holding the flex circuit under the mode switch (red cicle).
    • The yellow square points out a small ribbon cable going to the LCD screen. This ribbon cable powers the backlight for the LCD display. Gently pull out the ribbon cable from the connector.
  11. Canon PowerShot S500 Teardown: шаг 11, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • On the front of the camera is a 2nd ribbon cable going under the camera to the LCD screen - this one contains the data and timing signals which drive the display.
    • Carefully lift the black plastic latch and then pull the ribbon cable out of its connector
    • The large black integrated circuit on the left is an NEC microprocessor, apparently a custom variant of an 80186. Above the tripod socket is a small battery - for maintaining the real-time clock.
  12. Canon PowerShot S500 Teardown: шаг 12, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Remove the 2 screws holding the LCD display module (already removed from the rest of the camera in this photo)
    • It's not visible in this particular photo, but the LCD display module is made by Sony - part number "AM313EKA"
    • The LCD is a 1.8" active matrix TFT LCD
  13. Canon PowerShot S500 Teardown: шаг 13, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 13, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • There are 3 more ribbon cable connectors on the front of the camera. Gently flip up the black latches at each connector...
    • ... and then the ribbon cables can be detached.
  14. Canon PowerShot S500 Teardown: шаг 14, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 14, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Near the flash, there are 2 connectors...
    • Gently pull the connectors out of their sockets.
  15. Canon PowerShot S500 Teardown: шаг 15, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • The shutter button can be removed by simply releasing the 2 small catches (one outlined with a yellow square, the other hidden by my thumb)
  16. Canon PowerShot S500 Teardown: шаг 16, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Remove the 4 screws holding the main logic board to the rest of the camera.
  17. Canon PowerShot S500 Teardown: шаг 17, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Before you can remove the logic board, there's another ribbon cable to detach...
    • ... gently flip up the blue catch on the socket then slip the ribbon cable out of the socket.
  18. Canon PowerShot S500 Teardown: шаг 18, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Gently lift the bottom edge of the PCB, and you'll see one more narrow white ribbon cable attached to the bottom side.
    • Gently pull the ribbon cable out of the socket (there's no latch on this connector)
  19. Canon PowerShot S500 Teardown: шаг 19, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here's the PCB flipped up and away from the camera chassis.
    • Note: there are 2 flex circuit paths connecting the circuit board to the chassis - they are soldered and can't be detached without re-soldering. Be careful not to bend the flex circuit too severely or it may break. I had to resolder one of the connections after I was done.
  20. Canon PowerShot S500 Teardown: шаг 20, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here's the back of the main logic board. Note the DIGIC chip (main camera processor chip)
  21. Canon PowerShot S500 Teardown: шаг 21, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 21, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • With the main logic board swung aside, the target of our repair is nearly visible! - the lens module...
    • The 2nd photo shows another view with the logic board out of the way. The clear plastic insulating sheet holding the lower metal plate is fastened under here and can now be removed
  22. Canon PowerShot S500 Teardown: шаг 22, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Under the ribbon cables there's another small circuit board. This one is connected to the lens module and appears to contain various motor control chips.
  23. Canon PowerShot S500 Teardown: шаг 23, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 3 Canon PowerShot S500 Teardown: шаг 23, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 3 Canon PowerShot S500 Teardown: шаг 23, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 3 ΠΈΠ· 3
    • Remove the 3 screws holding the CF card slot.
    • Lift up the CF card slot - in the 2nd photo you'll see a ribbon cable going through the slot to the front of the camera. We earlier disconnected this ribbon cable from its socket on the front of the main PCB.
    • Simply pull the ribbon cable out, but be sure to note the slot it goes through for later reassembly.
    • The 3rd photo shows the rear of the camera with the CF card slot removed.
  24. Canon PowerShot S500 Teardown: шаг 24, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 24, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Back on the top of the camera, gently pull the white connector with red/black wires out of the socket.
    • Now gently pull up the flex circuit and the socket away from the camera top
    • The 2nd photo shows the flex circuit and socket from the last step lifted away from the camera. This will now allow us to separate the plastic chassis of the camera from the lens module assembly in following steps...
  25. Canon PowerShot S500 Teardown: шаг 25, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Remove the 2 screws (rshown already removed - marked with red circles)
    • Now you can separate the plastic chassis on the right (battery compartment) from the lens module/flash/viewfinder assembly on the left.
  26. Canon PowerShot S500 Teardown: шаг 26, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here's a view of the lens module/viewfinder/flash assembly (bottom) separated from main logic board/battery compartment (top)
  27. Canon PowerShot S500 Teardown: шаг 27, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • At the bottom of the lens module assembly is the larger of 2 motors (yellow square) - this is the motor that extends/retracts the lens.
    • We now want to get to the geartrain driven by this motor to see what's causing the problem.
  28. Canon PowerShot S500 Teardown: шаг 28, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 28, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Remove the 3 screws shown here.
    • 2nd photo: After removing the screws, you can separate the electronic flash module (left) from the lens module (right)
  29. Canon PowerShot S500 Teardown: шаг 29, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here is the electronic flash module.
    • **WARNING** there are very high voltage circuits involved in driving the flash. The capacitor (big black cylindrical item under the small circuit board) holds a large charge and could cause an electric shock - handle with care. Fortunately all the circuits here seem well insulated and there are no exposed high voltage contacts.
  30. Canon PowerShot S500 Teardown: шаг 30, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here's a view of the lens module after removing the flash module. That's the optical viewfinder towards the right of the unit.
  31. Canon PowerShot S500 Teardown: шаг 31, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 31, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Remove the first of three screws fastening the optical viewfinder to the rest of the lens module...
    • ... then remove the second screw (2nd photo).
    • The optical viewfinder can be separated from the lens module - however it's still joined by a flat flex ciruit - be careful not to damage this flex circuit; just leave the viewfinder dangling to the side.
  32. Canon PowerShot S500 Teardown: шаг 32, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 32, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • The geartrain for the lens retraction motor is inside this corner of the lens module.
    • (Note in this photo, the optical viewfinder is still attached to the right)
    • In the 2nd photo, viewed from another angle there's a hint of the lens retraction geartrain - the small white gear visible through a hole in the back. The lens retraction motor is highlighted with the yellow rectangle in the 2nd photo.
  33. Canon PowerShot S500 Teardown: шаг 33, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • These 2 screws need to be removed before separating the lens module front and back halves.
  34. Canon PowerShot S500 Teardown: шаг 34, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 34, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • Removing this small screw circled in red will free the small metal plate on this side of the lens module assembly.
    • In the 2nd photo the small plate is being removed.
    • You can now see the main large brass gear which drives the lens unit in and out, and also a slider/cam that zooms the optical viewfinder (yellow square)
  35. Canon PowerShot S500 Teardown: шаг 35, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • By gently pulling apart the front and back halves of the lens module assembly, we expose a black gear and white gear connecting the larger brass gear to the motor
    • Using tweezers it's possible to remove the black gear without fully opening the lens module halves - just open wide enough like shown here to gain access.
    • Note: the flex circuits around the lens module are soldered and cannot be removed. Therefore you need to gently carefully move them aside when pulling apart the lens module.
    • On the right side of the photo, there's a small plastic piece with flex circuit attached. This piece is held by one of the screws and the front/back halves of the lens module. When reassembling it's a bit fiddly to get back in the right place if you're not paying attention.
  36. Canon PowerShot S500 Teardown: шаг 36, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Success!! by removing the small black gear in the previous photos, I was able to manually spin the big brass gear to extend & retract the lens.
    • Upon closer inspection I found some sand or grit in the black gear - it must have been jamming the geartrain, causing the E18 error.
    • With the gears cleaned, I could reassemble and test the camera. No more E18 error - the lens extended and retracted again normally.
  37. Canon PowerShot S500 Teardown: шаг 37, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Wait!... not so fast. After reassembling the camera, I found a huge piece of dust on the sensor in all the new images I took. Dust must have entered the lens module during disassembly. I had to take the camera apart completely again! This time, to open up and clean the lens module. :-(
    • So here is the lens module again, with the 2 halves pulled slightly apart to clean the sensor and/or inner lens elements. It was easier to disassemble the camera the 2nd time :-)
  38. Canon PowerShot S500 Teardown: шаг 38, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Here are the lens module with front and back halves separated. The sensor is under the rear lens element (yellow circle)
    • The optical viewfinder (top) and the front of the lens module (right) are also visible here.
  39. Canon PowerShot S500 Teardown: шаг 39, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 2 Canon PowerShot S500 Teardown: шаг 39, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 2 ΠΈΠ· 2
    • In the rear half of the lens module, you can see some of the dust on the other side of the rear lens element in this photo. The sensor itself was clean.
    • This rear element is spring mounted and can be driven forward/back for focus by a second smaller motor.
    • The 2nd photo shows another view of the front half of the lens module.
  40. Canon PowerShot S500 Teardown: шаг 40, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Three screws (red circles, shown here already removed) hold the ring surrounding the rear lens element.
    • With the ring removed, you can gently lift up the spring mounted rear element (yellow circle) with tweezers. I was then able to clean out the offending dust on the back of the element.
    • Time to reassemble everything (again!) - this time, everything worked fine AND no more dust spots in the images. Success!
  41. Canon PowerShot S500 Teardown: шаг 41, ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅ 1 ΠΈΠ· 1
    • Reassembling the camera involves following the previous steps in reverse order.
bac
Участник с: 10/13/09
9Β 829 РСпутация
Автор 4 руководств
5 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²
This is fantastic! Very detailed. I'm sure it will be quite helpful to people.
Kyle Wiens - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Jeez! Would you instruct everyone else on how to put together a document like this! Fantastical patience and attention to detail.
jeff - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Now I just got to figure out how to remove the battery door from my SX130is, I've got the replacement door and hopefully this guide will help me figure out which screws to undo to remove it....
Darren Forster - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
This is, by far, the epitome of tutorials! Your images...perfect! Spelling...perfect! Content...perfect! I do a lot of writing and reading online and your work here is one of the best! Like you, I had nothing to lose tearing apart my Canon since it wouldn't open. I wanted something, anything, to guide me. I found your tutorial and wow! I followed your steps and it worked out. I'm going out now to take pictures with my Canon! Thank You!!
Ms Millar - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Just came across this. What a wonderful tutorial! I’ve had my S500 in a box for years after the LCD, I assume, failed twice in a year. With nothing to lose at this point, I’ll take a crack at it myself, even though I’m unlikely to use this camera much at this point. Thank you!
ericjs - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 6
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 30
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 120
Π—Π° всё врСмя: 42,109
