Инструменты для этого Разбора
Видео обзор
Введение
This year’s Pixel phones were leaked into oblivion, so when the keynote finally came, the internet gave a collective shrug. But you know what wasn’t leaked? The insides! And there’s only one way to get to get to those—with a teardown!
Want even more exciting teardown news? Check out our YouTube channel, follow us on Twitter, Instagram, or Facebook, and subscribe to our newsletter.
Normally we're all about high resolution, but this is shaping up to be the most Pixellated teardown ever. Check out the specs on our teardown unit:
6.3" OLED display with QHD+ 3040 x 1440 resolution (537 ppi) and variable refresh rate up to 90 Hz
Octa-core 64-bit Qualcomm Snapdragon 855 processor, paired with 6 GB of LPDDR4X RAM
Dual rear-facing camera with one 12.2 MP ƒ/1.7 wide-angle module, and one 16 MP ƒ/2.4 telephoto module; single 8 MP ƒ/2.0 wide-angle selfie cam
64 GB of onboard storage (128 GB optional)
IP68 ingress protection rating
Android 10 mobile OS
Lining up our new Oh So Orange Pixel 4 XL against last year's Clearly White 3 XL invites a few observations:
Notable changes include the loss of (one of) the front-facing speaker grilles and the fingerprint sensor of yesteryear. The new speaker setup still counts as stereo sound, but the lower speaker fires out the bottom (like an iPhone) instead of at your face.
The SIM tray also packed up and moved, likely to accommodate aforementioned speaker placement.
The Pixel 3's notch has evolved into a whole bezel! While everyone else in the industry works furiously to eliminate notches and bezels, Google's approach seems a little more laid-back.
At least they put the space to good use: inside they've crammed infrared facial recognition hardware, a wide-angle front-facing camera, and a cool new radar thing.
If this phone came with repair instructions, we're sure the first step would say "Apply heat to the surface marked in orange." So, we do just that.
The adhesive underneath is mercifully thin, but strong nonetheless. At this point, we'll take anything over that thick goopy gunk from last year.
With no more fingerprint sensor, we hoped to cut in without encountering any flex cable booby traps—but alas, a new even shorter cable connects the miscellany on the rear camera bump: flash, microphone, and the spectral + flicker sensor.
Fortunately, the wireless charging coil & NFC coil, newly adhered to the back panel via a sheet of adhesive, use repair-friendly spring contacts.
We might not need all 112 bits to dismantle this Pixel, but we're glad we brought our Manta Driver Kit along for this one! We fish out a Torx 3 bit and start twirling away screws.
Normally, we love pulling out stretch-release adhesives—they're far more repair-friendly than messy tapes and glues. But you gotta pull at a shallow angle to avoid snagging and breaking them, and good luck doing that here. Like in the 3 XL, you'll likely need to remove the motherboard for adequate clearance, which requires many additional steps.
With the benefit of experience, we carefully complete the battery extraction using some IPA and gentle prying.
Underneath, a small but serious landmine lies in wait for would-be repairers: a delicate Active Edge flex cable, just begging to be accidentally sliced during battery extraction.
We have to dispose of quite a few brackets and shields on our way to the motherboard, but it's all worth it for these chips:
6 GB of Micron LPDDR4X RAM layered over the Qualcomm Snapdragon 855
SK hynix H28U72301CMR 64 GB Universal Flash Storage
Samsung K4U4E3S4AF-HGCJ mystery RAM, with a big "P" on it—best guess, this is dedicated RAM for the new Pixel Neural Core chip, likely hiding directly underneath
Pixel H1C2M3 Titan M security chip
Knowles 8508A quad-core audio processor, no doubt to help with the new live caption and transcription features.
Murata SS9709025
Avago AFEM-9106 (likely a front-end module)
Side B of this record features:
Skyworks Sky5-8212-11 front-end module
Qualcomm QET5100 envelope tracker
Qualcomm PM8150 and PM8150A PMICs
STMicroelectronics ST54J NFC controller
Maxim MAX77826 companion PMIC
XSPT6 SMC85201 Z
Cirrus Logic CS35L36CWZ audio amplifier
Chip ID, director's cut part 1:
Maxim Integrated MAX11261 6-ch. 24 bit delta-sigma ADC
Renesas (Formerly IDT) P9221-R 15 W wireless power receiver
Cirrus Logic CS40L25 haptic driver
Qualcomm PM8150S power management IC
Samsung S2MPG01 wireless charging chip (likely)
Dialog Semiconductor mixed signal array
Chip ID, director's cut part 2:
Qualcomm SDR8150 RF transceiver
Skyworks SKY78215-11 front end module
Skyworks SKY77365-11 quad-band GSM/GPRS/EDGE power amplifier module
Skyworks SKY13726-11 LMB/MB/HB/UHB diversity receive module
Skyworks SKY13727-11 MB/HB/UHB MIMO diversity receive module
Skyworks SKY53735-11 LB/LMB/MB/HB diversity receive module
Chip ID, director's cut part 3:
ON Semiconductor EMI8031MUTAG common mode filter w/ ESD protection
Texas Instruments TS3A5018 4-ch. SPDT analog switch
ON Semiconductor FSUSB242UCX USB-C analog switch
Bosch Sensortec BMP380 pressure sensor
STMicroelectronics LSM6DSR 3-axis accelerometer/gyroscope
STMicroelectronics LIS2MDL 3-axis magnetometer
We'll work on tracking down its origin. Meantime, if you know more than we do, give us a shout in the comments!
The chip package is marked:
S4LV001A01 NGWF6YY5 1930—likely Google/Samsung neural core
The dual rear cameras come out, joined at the hip. They are nicely labeled "wide" and "tele" on the flex cables. Thanks, Google.
Next out: the front-facing sensors, including the 8 MP front-facing camera, and the
Face IDface unlock hardware. (The ambient light sensor stays stuck to the display for now.) -
The biometric hardware consists of two well-separated Near Infrared (NIR) cameras, a NIR flood emitter, and a NIR dot projector.
Next we pry out this hunk of ... stuff, which turns out to be an earpiece speaker, mic, ambient light sensor (AMS TMD3702VC), and the Soli chip, for interpreting your gestures using the power of radar.
Google calls this implementation of its in-house Project Soli Motion Sense.
Although radar technology has been in use for a long time and seems simple enough on paper, we're at a loss as to how Google stuffed the entire system into a tiny featureless rectangle with no moving parts.
The Soli chip then studies the reflected waves and analyzes their time delay, frequency shift, and other data to learn the characteristics of the object that reflected them—how big it is, how fast it's moving, in which direction, etc.
Soli then runs that data against its known gesture database to determine what action, if any, needs to be performed in the OS.
TL;DR: magic rectangle knows your every move.
Google gifted this Pixel with a supersmooth (sometimes) 90 Hz screen—a rarity thus far, even amongst the flagship-iest of smartphones.
Google also made sure nobody could take it from the Pixel without a struggle. Strong perimeter adhesive + screen layers going literally to the edge + giant duct-tape-like adhesive pad = screen does not want to come out intact.
In theory there's no reason to do this—only broken screens need be removed this way. But this is not a fun process for replacing an (all too common) broken screen.
On board, we also find a somewhat unexpected chip package from STMicroelectronics, likely a capacitive touchscreen controller.
GigaDevice GD25LH80C 8 Mb serial flash memory
While its construction remains (disappointingly) familiar repair-wise, we did find quite a few treats in this pumpkin:
The Motion Sense-managing Soli chip lives next to the speaker at the top of the phone, and is incredibly tiny, considering its functionality.
Our best guess is that the Pixel Neural core is layered under some dedicated Samsung RAM, meaning it must be doing some heavy lifting.
We also found a new Knowles audio processor chip, which is likely a major player in all of the new on-device speech recognition features.
Samsung made the 90 Hz-capable display—looks like Pixel beat the Galaxy phones to the punch on this feature.
But back to that familiar feeling—what will this phone score?
- All screws are standard T3 Torx fasteners.
- The stretch-release adhesive securing the battery may not be foolproof, but its inclusion is repair-friendly.
- Waterproofing measures complicate repairs, but hopefully make them less common.
- Display repairs continue to be difficult, requiring complete disassembly of the phone.
- All repairs require access through the stubbornly-glued back panel.
- Glass on the front and back doubles potential drop damage.
Заключительные мысли
Уровень ремонтопригодности
(10 легче всего ремонтировать)
Комментариев: 37
Any indication of why WiFi 6 is not supported despite being supported by the CPU? Is it missing a chipsets or antenna configuration that other WiFi 6 compatible phones have (that use the same Snapdragon 855 processor)?
The Murata WIFI chip in Step 5 does not support WIFI 6.
Ugly, not repairable, 2016-like specifications on a 2019 smartphone? Will NEVER buy for $1000
How does the FCC even allow this?
Lol - chill out buddy. And why would the FCC have anything to do with allowing a product to be released / priced / etc.? Unless you’re referring to the use of the Soli radar bands…
Matt J -
Remember all those phones from 2016 with 90 Hz refresh rates, radar, face unlock, e-sim.
