Выберете то, что вам нужно
Это разборка для изучения а не руководство по ремонту. Чтобы отремонтировать Logitech POWERPLAY, воспользуйтесь нашим сервисным руководством.
  1. Logitech POWERPLAY Teardown, Removing The Screws: шаг 1, изображение 1 из 1
    • The picture shows the sticker and screws removed.
    • Option 1: You can choose to cut out holes in the sticker where the screws are if you want.
    • Option 2: You can choose to rip the sticker off carefully if you want to put it back on again, if that's what you prefer
    • Now be careful when you open it, there is a ribbon cable connecting the charging pad to the housing PCBs. See next step for reference.
  2. Logitech POWERPLAY Teardown, Opening & Getting PCBs Out: шаг 2, изображение 1 из 1
    • So as mentioned in the previous step, there is a connector for a ribbon/flex cable on the charging board.
    • You need to take out the 3 screws from the PCBs then carefully take them out and disconnect the cable
    • Now you're left with two connected modules. There is a 4 pin connector that you can just disconnect.
    • That should pretty much be it for the teardown. Look at the next steps to get a closer and more detailed look at the internals.
  3. Logitech POWERPLAY Teardown, Main Module - Closer Look: шаг 3, изображение 1 из 2 Logitech POWERPLAY Teardown, Main Module - Closer Look: шаг 3, изображение 2 из 2
    • This is the main module that handles the USB-connection for the data connectivity for the wireless receivers as well as power for both the receivers and the charging module (see next step).
    • This module alone can act as a receiver for your Logitech LIGHTSPEED devices. Though I'm unsure how many devices it can connect simultaneously.
  4. Logitech POWERPLAY Teardown, Charging Module - Closer Look: шаг 4, изображение 1 из 3 Logitech POWERPLAY Teardown, Charging Module - Closer Look: шаг 4, изображение 2 из 3 Logitech POWERPLAY Teardown, Charging Module - Closer Look: шаг 4, изображение 3 из 3
    • This is the charging module that connects to the wireless charging transmitter coil.
    • In the first picture you can see the connector on the left side of the board (white with slightly open lock).
    • Although I haven't tested, it should work just fine for charging if you can supply power to the 4 pin connector on the board.
    • Without being an expert on the topic, I'm assuming that the 4 pin connector is just a USB 2.0 spec connector to communicate some information from the charging module to the main module. (so 2 pins for power and 2 for data)
    • Last picture is of the ribbon cable that connects to the power output port on the charging module.
Nozemi
Участник с: 05/10/17
289 Репутация
Автор 2 руководств
4Комментарии к руководству
What in the mouse pad section? How does the mouse charge is there just a giant coil in the mouse pad area?
evilsanta8585 - Ответить
If I remember correctly, yes. I haven’t taken it apart, because it’s not possible without destroying it.
FCC has some pics of the internals I think.
Nozemi -
how can i troubleshoot what is wrong with it, when it isn't charging annymore?
Adriano Paganini - Ответить
Do you know the max height of this?
Lukas Lindström - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 22
За последние 30 дней: 105
За всё время: 4,143
