Помощь
Logitech POWERPLAY Teardown
Редактирование шага 2 —
Тип шага:
Перетащите чтобы изменить порядок
So as mentioned in the previous step, there is a connector for a ribbon/flex cable on the charging board.
You need to take out the 3 screws from the PCBs then carefully take them out and disconnect the cable
Now you're left with two connected modules. There is a 4 pin connector that you can just disconnect.
That should pretty much be it for the teardown. Look at the next steps to get a closer and more detailed look at the internals.
Ваш вклад лицензируется под свободной лицензией Creative Commons .
