Введение
We got our hands on a MacBook Pro 13" Unibody and decided to compare it to a MacBook Unibody -- from the inside! Follow us on Twitter to get all the latest updates as we're doing the teardown!
Выберете то, что вам нужно
This just in: the new MacBook Pro 13" Unibody!
We'll be comparing it to the MacBook Unibody throughout the teardown.
We have a feeling it will be very similar in most regards.
Contents of the box:
User's manual
Restore DVDs
60-watt AC adapter
AC adapter extension cable
Cleaning cloth
No video adapter, as usual.
Some comparisons to the MacBook Unibody:
No access door for the battery on the bottom.
The addition of an SD card slot (and the omission of digital/mic port) is readily apparent.
FireWire is back!
Computer lock is now on the other side.
The SD card sticks out almost .5"! This is a cheeseball design for a MacBook "Pro" if you ask us.
is it possible for me to sell back my 4-6 month old macbook unibody 13'' back to apple or something so i can buy this? If someone could help me with this that would be great!
normally i would be fine with another apple update but i really need the upgraded battery, ram limit, cpu, firewire and sd card slot... and saving $200 and pro status would be nice also...
Цитата от(из) mcifix:
I hadn't noted the loss of the microphone port. Arghhh. Tradeoff to get firewire back is worth it, but still very unfortunate for some folks.
Actually, I think the mic port is still there... it's just integrated into the same port as the headphones, like the iPhone's is.
Will this battery work in the 13 inch macbook?
I don't really get the issue with the SD card sticking out -- seems like a normal design to me. You want to be able to have enough sticking out to grab onto to pull it out! If you had a flush mount you would need some sort of spring mechanism with a catch (like my digicam internals) or a spring and release button (kind of like the old pcmcia card slots). More mechanics/moving parts == more things that can break down IMHO.
Even my plugin USB SD card reader has this exact same clearance and I've never had an issue with it. Not like you would (should) be porting around your mac in your laptop case while you had an SD card plugged in. (although I know people who leave CD's in all the time but I think that's kind of dumb too.)
Цитата от(из) alecmv:
The battery will not be of same specification. That is why now it is only accessible by taking apart the entire outer enclosure, that way allowing for an increase in overall battery life.
Ok but if the aluminun botton cover could be replaced as well... would´t it be a solution to replace the old battery to the new MBP 13 battery?
What? No, definitely not.
By the way: you will loose your waranty by taking out the battery of the new MacBook Pro 13". There is label inside stating this.
solomo gutschein http://solomo-gutschein.blogspot.com/
Yeah, having the SD card stick out isn't a bad design. If it inserted flush, then you have to use a fingernail to push it in to activate the eject mechanism (and sometimes it's not easy to push it in far enough). And anyone who has dealt with SD cards knows, they can jam inside the slot, and become difficult to remove without tools.
With it sticking out, a firm grasp will remove it. The only issue I see is RS-MMC cards which if the adapter fails to catch the RS-MMC card, you can be stuck with it inside the slot.
RTFM. The Tech Specs on the product page clearly indicate that it is a combination input/output that is user selectable. It is also worth noting that it supports the Apple stereo headset with microphone.
Agree, agree, agree.
My 15" MBP has had an SD ExpressCard adapter in since day one.
It works the same way. Very durable. Cards go in and out multiple times daily.
My Lexar "Professional" USB SD/CF reader hooked to my Mac Pro works the same way.
Good riddance to spring-loaded card slots.
[quote|solomo] By the way: you will loose your waranty by taking out the battery of the new MacBook Pro 13". There is label inside stating this.
Any ideas how to change the harddisk ("still considered user-replaceable by Apple") without voiding the warranty?
I would need to disconnect the battery before replacing the harddisk, right?
The label does not indicate that your warranty will be void by removing the battery. However, you don't need to remove the battery to replace the hard drive -- you can just unplug the battery.
You will not void your warranty unless you break something.
I'd just use a USB microphone. The rockband one's are actually pretty nice.
Let's get down to business.
There's no door latch, going along with the "not user-serviceable battery" theme.
We had to dig out a Phillips screwdriver for this step.
A quick flip of the lid and...
I have used a #00 Philips screwdriver. Even using the angles here in http://manuals.info.apple.com/en_US/MacB... page number 38 in this manual, I was unable to unscrew the small screws near the opening latch (the ones on the sides and the long ones work btw).
Does anyone have a solution for this? I don't want to break the screws or damage the cover.
Im unscrewing all screws counterclockwise.
...It's almost exactly the same as our old, "lesser" MacBook Unibody.
The battery compartment is identical to the one we uncovered in the MacBook Pro 17" Teardown. We'll venture a guess that it looks the same in the updated 15" Pro as well.
Remove two tri-wing screws and the battery is suddenly replaceable. The sticker comes right off, just as in the 17" Pro -- because it's adhered to just the battery and midwall, not to the optical drive.
Actually, the battery will cost exactly the same amount as any user-replaceable battery--$129. Apple will likely offer (like they do with the iPod, iPhone, and 17" MBP) a battery replacement program that only charges the cost of the battery. They will have to take it away from you for 24 hours, but they certainly aren't getting more money from the new setup. Just setting facts straight.
Do you have to unplug/remove the battery in order to replace the RAM? Otherwise worded: if you remove the RAM with the battery still plugged in, could it damage the computer?
7-hour battery specifications:
Model A1322
10.95V
60Wh
"This battery contains no mercury (Hg)."
Although the batteries look similar, they're definitely not interchangeable. The MacBook Pro's battery is too large (and different in shape) to fit into the older MacBook Unibody.
"Warning: We'd really appreciate it if you'd pay us a bunch of money to replace your battery instead of just replacing it yourself!"
> When working on all machines that have internal batteries, disconnect the battery first to cut off power to the entire device.
Do you mean I have to remove the battery before to unplug the magsafe plug, cutting out power?
This means I had to remove the back cover with MacBook shutted off but powered.
Has the MacBook Pro 13.3" a backup battery?
Ps: nice teardown!
Removing the hard drive...
It's still considered user-replaceable by Apple, but replacement does require removing 10 more screws than on the MacBook Unibody.
First thing we'd do is replace the 160 GB Hitachi with something more meaty.
I second Raaza's question; and I'll add my own. I want to upgrade the HD (I Think) to the 500GB 7200 Drive you linked to, but I'm concerned about heat and noise issues. is there a huge performance boost between the offered 500 GB 5400 Drive? I am planing on buying the 1400 version so I get the 4GB RAM and the faster processor to start with. Is that worth the price?
Цитата от(из) blyccy:
I want to change the HD only, do i need the tri-wing screw driver to remove the battery? Or i can simply to unplug the power to cut the power?
You don't have to remove the battery. You can just unplug it before removing the hard drive.
To answer both your and Raaza's questions:
1. Replacing the RAM and HD does not void your warranty.
2. 5400 vs. 7200 RPM is debatable. The upgraded performance will be most noticeable on disk-intensive processes, but you probably won't notice much improvement by just normally using the MacBook.
Цитата от(из) opt1m4l:
Wait a second, so what screwdrivers do I need to upgrade my HDD and RAM again? It seems like Philips through and through but I keep hearing about T6 as well.
Цитата от(из) dennya:
Does the hard drive removal require a #6 Torx like earlier MBPs? Or is it a Phillips screw?
You need a #00 Phillips screwdriver to upgrade the RAM, and you need both the Phillips screwdriver and a T6 Torx to upgrade the HD.
A spudger may also come in handy to unplug the battery, but is not absolutely necessary.
FYI.. here is the Official Apple Hard Drive Replacement Manual: http://manuals.info.apple.com/en_US/MBPR...
Also, its a PH #00 screwdriver, not a #0. You also don't need to disconnect the power to replace the hard drive. I wish I would had known the screwdriver was in fact #00.. glad I took it easy on the &!&$ screws.
I would like to get myself a macbook pro 13", but i would like to have a 7200 rpm harddrive. In the apple-store it is not possible to configure this and i would like to know if there is a technical reason for this? Is it because the 7200rpm hd gets to hot and the and macbook pro can´t handlethanks it? - I wouldn´t want to put the hd in it if it´s going to break down :-) then i´d rather go for the 15". Thanks...
Thanks for the link that is really useful. But why do Apple forget (again) to say you need a T6 Torx for the guide screws on the drive?
Цитата от(из) iv26:
So, to install a hard drive on the new 13 Inch macbook Pro I will need a #00 Phillips Screwdriver and a T6 Torx, is that right?
You are correct sir!
The subwoofer comes off after removing two screws.
Цитата от(из) macdoofus:
Firewire Chipset - Can you tell me what brand is being used here? I am hoping for T.I. for external f.w. recording device. Thank you.
Has anything been said about the chip used for the firewire? I was told on RME forum that the new chip works well with their sound card. Just wondered if you had any more good news. D
you know what? be extra careful to remind to attach that micro-little piece of scotch tape to the superdrive connector… if you forget it the back cover of the mac will short circuit the Logic Board and result in a crash of the system…. Crazy but true!
The optical drive is attached via three Phillips screws.
The brackets and screw layout are identical to the older MacBook Unibody.
is it possible to replace the slot-in drive for slot-in bluray drive as this one http://bogielives.com/index.php?page=29&... ?
Is it possible to replace the trackpad on a MacBook Pro 13inc, my little boy hit it with a pen and cracked it. It still works just has an ugly crack on it. I see I can buy a new track pad just need some instructions on how to go about replacing it. This is my first Mac I am used to PC laptops so never opened a mac before. Some advice or tutorial would be great thank you.
Hi Melissa. Unfortunately, the trackpad is part of the Upper Case. If you wish to replace it, we have a guide for the MacBook Pro 13" Unibody Upper Case. Good luck.
Yes you can replace track pad and you don't need the whole unibody as I just took my track pad out with 4 little screws, just leave the the 2 in the middle of each little clip. You will see what im talking about!!
Removing the optical drive exposes the right speaker.
It's held in place by adhesive. A quick pry with the spudger will loosen it.
Disconnect the LVDS connector.
Remove 7 motherboard screws.
Remove 2 DC-in screws.
Disconnect trackpad, keyboard, and battery level indicator cables.
Remove LVDS cable retaining bracket.
And the logic board is almost out...
Pop out the microphone from its cave.
The logic board is finally free!
It appears removing the microphone should be easy. Is the wireless and bluetooth hardware still in the base of the display? I know the iSight is still in the display. Are all cables coming out of the display combined or are they separated by function (display and wireless/bluetooth/iSight)? Have you tried operating the MBP with these devices unplugged (if possible)? Thanks. (yes, I'm asking about it again)
Цитата от(из) nswien:
You mentioned the harddrive is user replaceable. Is the Ram also ? I just want to make sure that neither of these two changes will void the warrenty. Although I know that Apple will no longer warrenty either of the replaced parts.
Yes. My wife's MP13" arrived 2 days ago and I upgraded from 2 GB to 4 GB. Its very easy. You need a jewelers/eyeglass type Phillips screwdriver (very small tip) to remove the back cover screws. Just keep remember to keep the 10 screws in the same order as the hole they came out of because they are different lengths. The manual that comes with the notebook explains how to do it.
Awesome job on the tear-down. I purchased my 13" MacBook Pro about two weeks ago and already replaced the HD and Ram...very easy. Small phillips and torx, both of which I bought from Home Depot. What I didn't see in the tear-down is the wireless card. Is it soldered on-board or did I miss it as a mini-pci card?
The AirPort card on these machines is attached to the display, underneath the black plastic "clutch cover."
Цитата от(из) iv26:
which screwdriver will I need to take out the Hard Drive Bracket?
You'll need a Phillips #00 screwdriver for the bracket, and then a T6 Torx driver to remove the hard drive's side screws (if you're planning on replacing the drive).
Yes, the AirPort/Bluetooth card is hidden below the black plastic clutch cover at the base of the display. The display data leads reach the motherboard through one connector, and the AirPort/Bluetooth/iSight through another. We have not tried operating the machine with either cables unplugged, so I can't help you there. Check out our MacBook Pro 13" Unibody device page for detailed pictures and disassembly instructions.
A couple of images of the logic board, before we strip it naked...
Like the MacBook Unibody, the heat sink comes out along with the logic board.
Цитата от(из) anon4433:
Can you replace both RAM modules without pulling the motherboard? Or do you have to get it all the way out to do the one on the other side?
You can replace both RAM modules right after you remove the bottom cover -- no need to take out the logic board.
Judging from the pictutes that isn't true, it looks like only the first chip is accessable. Look at the first picture in step 11.. Aluminum blocks access to the other chip.
the ram slots look to be the same as the first unibody 13" and you can access both RAM chips without removing the logic board
can you take the vid processor off or is it soldered on? upgrade to the 9600???????
I disagree. Look at the middle picture in Step 11. You can see the other RAM chip peeking out from under the top chip. Looks like it'd be easy to replace.
I can confirm that RAM slots are the same as before. Differences are only the new battery and that you have to unscrew the bottom cover again.
RAM and HD remain user serviceable.
Is it possible to replace the harddrive with an SSD drive?
If so are there particular ones that will fit or not fit?
Can you recomend a worthwhile SSD to replace.
Thanks.
I'm also curious about changing the video card, but I'm glad to see that the hard drive and RAM are considered user-replaceable. Too bad it's still cheaper to buy the 8GB through Apple. 13" MBP user manual:
The manual only mentions that the drive must be a 2.5" SATA. There's a 250GB SSD for $900 at Newegg, which is the more than it is to upgrade from Apple (although you'd get to keep the 250GB 5400). There are some more affordable 128GB SSD drives, $250-300. However, they're just covered under a replacement policy, no refunds! So, it'd be nice to hear some first-hand anecdotal evidence about a particular brand working well. Or, better yet, which drives Apple uses as its OEM? I'm using just over 128GB now, and I'm not sure how much of that can be pared down just for the longevity and energy/heat/mass savings of a solid state drive.
Any SATA SSD will work. I'm running a Samsung 256GB SSD in my 15" unibody and I previously had a Patriot 128GB SSD in it. It pops in just like any other 2.5" drive (NOTE: Don't buy the Apple SSD from the BTO option; get an aftermarket drive from OCZ, Patriot or Samsung. The BTO SSD's have inferior read/write speeds.)
Is it possible to adapt the new battery from the MBP 13 (MB466LL/A) in the late 2008 MB 13 AL (MB990LL/A)??? Could ypu please reply to this question? I looks the same size and shape. The only point to observe is how to fix it to the main block of aluminun...
RTFM!
The video processor is soldered onto the logic board, and it would be very hard to upgrade it to a 9600...
Цитата от(из) Zews:
RTFM!
the ram socket is the clip up type not the push in type on the old macbook so you can replace it without removing the battery
I just got a 15" MacBook Pro the end of January, It is easy to replace the HD but I would a good 500GB 7200 RPM HD from OWC They seem to have the best price when I went for My 500GB in Mine. I mad the mistake of only getting a 5200 RPM drive, and get a FW 800 external case for the old 500 GB and do a Carbon Copy on it before putting it back in. The 500GB in my 15" MB Pro I may replace it but I most likely will do it when I get my student loan in the fall. and then Get a 13" MB Pro to use as a "NetBook" unless Apple will come out with a new machine in the fall?
Both sides of the logic board.
It looks like the Realtek ALC885 audio chip has been replaced with something else. I can't tell if the Cirrus labled chip or the chip with first line GL137 is the new audio chip. I figure one is the audio chip & the other is the SD card controller. I have tried to search the web for what these parts could be but I haven't had any luck.
Цитата от(из) Orpheus:
Yes, I would like to know if thermal paste is applied correctly as well. From the photos I can't see any thermal paste at all?
The thermal paste coverage on our MBP 13" Unibody seemed adequate. We cleaned the thermal paste off the surface of the processors so whoever is interested could easily identify the chips.
Is there any pictures of the thermal paste coverage? It'd be nice to see how much Apple applied.
For anyone who is curious about thermal paste coverage, here is a photo of the factory amount.
Цитата от(из) brdnboy:
For anyone who is curious about thermal paste coverage, here is a photo of the factory amount. http://www.flickr.com/photos/40248045@N0...
Geez, that looks horrible! I'll definitely redo the thermal paste when I change the HD.
Anybody know if the CPU is soldered in? I just got a 13" MBP this past weekend, and immediately swapped the ram for 4GB and the HDD for a 500GB unit, and while the processor is just fine right now I'm curious to know if it's able to be replaced later down the road.
Thoughts?
It is soldered to the board and is non-replaceable.
And here's the whole enchilada for you to enjoy.
Цитата от(из) macphisto:
Is the display still a 6-bit display from the previous generation? Or did they move it to the 8-bit (IPS?) display that is in the 15" and 17" MBP?
I'm not sure, but I can confirm that it's A LOT better than the Unibody MacBook.
The brightness "tearing" is gone and the viewing angles have improved.
From the short time I had with it I'd say it is at least on par with the previous 15".
And that's a great improvement for the 13".
15" and 17" never had an IPS display. These are all TN displays.
Not true. The "new" 17" uses an S-IPS panel.
And it's awesome.
I'm not sure what they did with the 15" and 13". They surely had TN panels before and I'm pretty sure still have TN panels, but they are a lot improved. Especially the 13".
Does anyone know if I can replace the backlight keyboard with an older one? I spilled coffee on mine, and a few letters don't work, I want to replace it, but cant afford the backlight one. Any suggestions would be greatly appreciatted.
10 Комментариев
Hi. AMAZING walkthrough and I really love your website. I need HELP!
I bought a refurbished MBP 13-inch 2.26 GHz and I don't think it came with a wireless card (I think I got ripped!). Bluetooth is working but my airport says "No Airport card installed".
Anyway - is it possible to check if the wireless card is in there? If not, is it possible to replace it? Any help and advice would be greatly appreciated!!!
The AirPort card is hidden in the display. We don't have a guide specifically for it, but you can follow the display guide to remove the display and then use the clutch cover guide to access the AirPort card (you don't have to remove the front display glass to access the card; the clutch cover guide was part of another guide for the LCD but the steps are generally the same).
great guidelines.... I have a macbook pro mid2009 A1278. buzzing sounds coming out when I play any music. is there any fix?
Hi, I have a macbook pro Mid 2009, now it very slow. can it upgrade? If it must upgrade What I I do for it?
Give me some your opinion, Thank you very much!
Sicerely
Tao Nguyen
nnhattao@yahoo.com
Hi Tao. Two most important things to upgrade are RAM and disk. Which one it depends on how you use your Mac, but if you can upgrade both, do it. Your laptop model can have as much as 8 GB of RAM (2 x 4GB). Increasing it helps a lot and it allows you to have more apps open and/or more tabs in your web browser, etc. Replacing your old HDD with an SSD will give you instant speed increase that will shock you. Absolutely recommended. And you can even keep the old HDD and use it instead of the built-in DVD drive (that I hardly ever used). Good luck.
Martin -
What's the piece just inside from the magsafe port that negotiates charging with the battery?
only two of my keys broke from the X latch. advice on which keyboard to purchase or if i can pop in new keys?
Hi, need some advise from you experts.
I have the older MacBook Unibody 13" and waiting for the arrival of this MacBook Pro 13".
1) Can I just interchange my 500GB hard-drive in the old machine to this new machine ? Will both still function ?
2) Both Mac OS is the same 10.5.7 ?
3) When will iFixIt sell 4GB RAM for this new Unibody ? Apple upgrade is really expensive.
Thanks guys.
KMCK - Ответить
No! I just through my 500gb drive from my unibody macbook pro into my brand spanking new 13" macbook pro, and when i booted, I am not able to get sound (internal speakers is missing in control panel) and also i noticed the firewire 800 port is not working. I dont know if the firewire port was working before the swap, but i KNOW i got sound. I'm PRAYING that i didn't screw something up because the cover did seem to stick on something in the back-right corner when i lifted it off, but i'm thinking its probably just the drivers. The build number is different even though both drives had 10.5.7 on them.
Re-installing 10.5.7 on the 13" now (with CD's that came with it) and will let you know what happens.
-Dave
griffd - Ответить
Thanks Dave, hope it's gonna be alright for you !
KMCK - Ответить
Could someone please list the exact model # of the build-in hard drive (the one that come with the laptop) in the new MacBook? Also, if you also have the part # for the memory it would be much appreciated too. Thanks.
mather - Ответить
I have the Macbook unibody and can't stand the screen - does anyone know if I can just buy the 13" MacBook Pro top panel and replace the screen? (i.e. same dimensions, connector etc??)
22yrmacuser - Ответить
I swapped in a 500GiB drive with 10.5.7 from another MacBook, and it booted fine - but as Dave said, the iPhone-style combo audio port wasn't available. I archived-and-reinstalled the OS from the DVD that came with the MBP and have had no problems since.
The built-in speakers are really nice, btw.
deedle - Ответить
The drive is labeled: Hitachi 5K500.B-160, HTS545016B9SA02, type TS5SAA160. In smaller print it also has the following label: D33373 HTB-TS5SAA500(B). 5V, 700mA. May-09.
Below, Apple labels it: HDD Firmware 2008, 160GB, 2.5inch, AT 9.5mm, P/N: 0A70461, MLC DA3031 A845221.
deedle - Ответить
jim0266 - Ответить
Apparently not. I called Apple and they will not replace the screen even if you pay for it. I also called several top Mac shops and the cost was prohibitive. In the end I sold my 2 month old 2.4/4 UMB for $975. In the end it cost me $300 to upgrade to a 2.26/4 MBP. I lost .14 GHz but gained firewire, a much nice screen, an SD card slot and new batter technology, so the cost was worth it to me.
jim0266 - Ответить
What kind of Ram and hard drive can you recommend from newegg?
I'm buying the lowing end 13inch MBP and want to upgrade the ram from 2 to 4gb, and the hard drive from the 160gb to a 500gb. Any recommendations? Links to newegg maybe?
Sethal - Ответить
散热管太水了
Hiller89 - Ответить
The 160GB Hitachi Drive show "HTS545016B9SA02" for the model number.
Simon - Ответить
I may or may not have spilled some tomato soup near my trackpad of my unibody MacBook Pro...and though it is still functioning properly, seems like it could use a little cleaning along the clicking edges. Can anyone point me in the direction of a trackpad removal tutorial so I can give it a once over and get it back to un-gunked satus? Cheers
Scott
FEaddict@gmail.com
Scott - Ответить
Can I use the PC standard 4G DDR3 Ram install into the empty slot? Coz I have one 4G DDR3 ram spare.
Thanks
arypnh - Ответить
