Выберете то, что вам нужно
Видео обзор
- External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
- Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
- The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
- Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
- Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
Заключительные мысли
Уровень ремонтопригодности
7
Ремонтопригодность 7из 10
(10 легче всего ремонтировать)
6 Комментариев
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - Ответить
where can I find replacement parts?
Michel - Ответить
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - Ответить
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - Ответить
https://www.endrich.com/sixcms/media.php...
K T - Ответить
