Выберете то, что вам нужно
Видео обзор
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Samsung Galaxy Buds Pro, воспользуйтесь нашим сервисным руководством.
    Заключительные мысли
    • The charging case is very easy to disassemble. Its battery is modular and easy to access and replace.
    • Some force is required to open the Buds, which can lead to some slight cosmetic damage and is a daunting first step for a repair.
    • The Buds are only semi-modular: their main circuit boards are easily accessible and held down with Phillips screws, but their batteries use soldered connections.
    • The Buds' drivers are practically inaccessible, making their eventual replacement tedious at best, but most likely downright destructive.
    Уровень ремонтопригодности
    3
    Ремонтопригодность 3из 10
    (10 легче всего ремонтировать)
Taylor Dixon
Участник с: 06/26/18
67 116 Репутация
Автор 94 руководств
10 Комментариев
Samsung making less repairable earbuds: “It’s evolving, just backwards.”
Ethan Zuo - Ответить
Is dropped one ear bud few times and touch control stopped working one it ..except that everything works fine even the volume control…how to fix it?
Jakub Serafin - Ответить
I love how easy the case is to take apart, however I cannot seem to locate a replacement battery for the charging case. Any idea where I could locate one?
Trevor Reed - Ответить
Looks like the Galaxy Watch 46mm battery!
https://www.reichelt.com/de/en/battery-f...
I haven't tried it tho, but will have to soon because my Buds Pro case got water damaged. Thankfully it charges the buds but not the case, so I'll try to replace the battery and see if that helps.
Oscar de León -
Found the one! After disassembling my case I could check the actual part number
https://www.ebay.com/itm/354134695747?ha...
Oscar de León -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 18
За последние 7 дней: 152
За последние 30 дней: 540
За всё время: 24,839
