Введение
A look inside the Samsung QLED TV Smart Remote
Выберете то, что вам нужно
Samsung QLED TV Smart Remote with Voice Command via Samsung's Bixby, and WiFi Direct
To open the Samsung Smart TV Remote, flip the remote over and slide the back cover down in the direction on the indicators.
Sliding the backside on the remove toward the indicators will expose a small gap on the front side of the remote.
The exposed gap allows for easy gripping of the back cover, so that the back cover can be removed.
Removing the back cover exposes the battery compartment, and pairing instructions for the remote.
Not happening! I will never buy a Samsung again.
I do not understand why mine doesn’t work when I do this! It just won’t budge.
I agree…it's not moving! Now what? Can't use the TV without the $5.00 remote…horrible!!
This control is a piece of $@$*. I may return the TV just because of the control!!!
My wife made a tiny gap at the back with a knife and pushed it - hurrah it worked
I’d like to see the CEO of Samsung open this remote. Horrible design.
Who designed this ?????? Does not work!
Sept 2nd, My brother and I have both tried…. not budging at all!
I agree with everyone about everything. My husband has lost his soul over it I think. He says that you need to push down and in at the same time, but only a little bit. The little clip on the top has something to do with it too. Just below that clip, push down a bit. It may or may not work for you. It took him a half an hour and use words I’ve never heard from him. Give it another try, you just never know. ??
The rest of the remote is held together with plastic clips.
On the right side of the remote, when the remote is facing up, there are two large chip opening areas. These large clip opening areas are only located on the right side of the remote.
To open the remote enclosure, a Plastic Opening Tool can be use to start the separation of the enclosure seam via the large clip opening areas. Then a Spudger Tool can be used to pry open the enclosure.
Once the enclosure starts to open, gentle move along the outside of the remote enclosure seam with the Spudger Tool to release the remaining enclosure clips.
What an absolutely idiotic way to take a simple panel off of the remote. This destroys the remove. I’ve been very careful and followed the instructions, but there’s no way to do this step without destroying the remote, so thanks for designing the worst remote of all time.
Tried this for over 30 mins. Couldn’t pry it open. All it did was damage the plastic on the case and bent one of my tools. So frustrating that Samsung made this not to be repaired.
After lifting the back you should start going upwards. I used the opening tool and pick to lift the top, right next to the transparent plastic. From there it is quite easy, just use the opening tool and be patient.
Opening this remote is tough, I was slow and careful so it took me about 30 minutes the 1st try, but the 2nd, 3rd, 4th, time I opened it in I swear 30 seconds. The trick is to use the tool as shown in the picture, snap the first clip open, then grab the guitar pick tool and slide it inside the opening, now slowly slide the pick up and down like a letter opener, as you travel up and down with the pick you will hear and see the clips snap off. Once you have a couple of clips out, use the guitar pick tool and jam it in the opening, so it holds open the clip, and with a 2nd pick, continue to slide up and down the remote. The reason you need 2 pick tools is because the remote tends to close itself when you are handling and moving it trying to open all the clips. Also note, I did 1 step that is not listed here, I saw this in a video, the person used the picking tool to snap off the little window at the front of the remote, after removing the little window the video opens the remote as shown here.
Hope this helps!
Once the enclosure has been opened, the top part of the enclosure, and rubber membrane keypad can be reviewed.
The remote keypad area on the back of the PCB is made out of dome tactile buttons.
To remove the PCB from the enclosure, use the Spudger Tool to gentle pry up on both sides of the bottom part of the PCB near the battery compartment area. This will release the PCB from the PCB enclosure.
A close inspection of the tactile button side of the PCB revealed two small holes. These small holes turned out to be port openings for dual MEMS Microphones found in the remote.
Also, found during the close inspection of tactile button side of the PCB was that the two horizontal buttons on the front face of the remote are also able to contact tactile buttons above and below the tactile button they rest on, which means that the user can push down, push up, or pull down when using those buttons.
A LED was also located near one of the Microphone port holes.
Location of MEMS Microphone on the topside of the remote enclosure.
The Bottom MEMS Microphone is located under the two horizontal buttons of the remote.
There are acoustic gaskets in contact with each MEMS microphone when the enclosure is assembled.
The top part of the remote enclosure has the acoustic gasket for the top microphone.
The rubber membrane keypad of the remote is used as a acoustic gasket for the bottom microphone.
Turning our attention to the backside of the PCB, we can review the components that give the remote its functionality. There are a number of discrete parts, transistors, and power supply ICs. Plus the components that were cross referenced listed below. Some parts could not be cross referenced. Leave comment if you know a part.
Universal Electronics Voice Controlled Remote Controller with WiFi Direct UE878NMEG
WiFi Chip Antenna
Infrared LED
add a comment
added……………. a
Что за деталь находится на плате обозначена как Х201 ? рядом с UE878NMEG и W25Q40BWSNIG
Teardown Exploded Views of the Frontside and Backside of Samsung QLED TV Remote
36Комментарии к руководству
Impossible to open this remote
I finally found out why my remote turns on bixby all the time, its the Vesprr wake up mic: https://us.community.samsung.com/t5/4k-8...
Samsung support say the replacement mics don't have it. Looks like this wake up technology doesn't work.
Great instructions. Some food goo got on under the click wheel, and was stuck on one side. Cleaned it up after disassembly. Ifixit is the best!!
Thanks a lot for the detailed and fully explained instructions but unfortunately even after opening the remote drying it fully and reassembling it didn't work.
Never would have gotten this apart without you. Just need a cleanup where it was getting stuck. Saved me over 40 bucks for a replacement. Greatly appreciate the help!
HI Thanks Great information.
My remote volume down is not working, but i cal increase the volume.
The idea of up / down movement is the issue i guess, it will not last for long like traditional remote. need to by new one
Currently using samsung mobile app for remote..
any suggestion,
Thanks..
Akash
Interesting, mine was the volume up - it works some of the time but not always. After taking it apart and cleaning it it has made no difference. The up causes it to click like it does down, so Im assuming that the up clicker on the circuit board is not making a good contact. I didn’t look at how easy it was to remove the sheet containing the click buttons from the board. Maybe next time i take it apart, I’ll look, and have a go at fixing it.
BrianS -
This remort's joy stick is not working from where use to backward the movie clip. How can u help me plz
Here is a useful video of someone’s One Remote disassembly. At 1:35, he unclips first two clips at remote’s butt with just fingers and the others with flat screwdriver.
my little girl dropping the controller into the water since the volume can go down but not go up do you have a solution
My Mom has this type of remote, with the Netflix, Prime Video and Hulu buttons on the bottom. She keeps clicking on these buttons by mistake. My question is, if I take this remote apart, can I disable these 3 bottom buttons? If so, how? Thanks so much!!
I just thought of something else. I could simply remove those 3 metal contacts, in the same fashion this person did in the below video. And then the buttons for Netflix, Prime Video and Hulu would no longer work.
seeley6 -
It worked. I simply removed the 3 metallic clickers/contacts from under the 3 buttons by cutting them out with a razor blade and now those 3 buttons are DEAD. Great! No more accidental clicking on those buttons.
seeley6 -
Very clear instructions! Many thanks…
my remote would not open either by sliding or pressing…extremely frustrating:- Alan NZ
Buttons clicking but not sending a signal usually means there is residue under the metal contact device. The mechanism under the rubber button is really surprisingly simple and resilient. The layout for the circuitry on each button is the same:
1) A solid circular dot shaped copper contact point, 2) A thin concentric copper ring surrounding the center dot.
There is a gap between the center dot and the surrounding ring. This is the electrical switch that is bridged when the button is pressed.
A small metal bulged plate sits on top of the circuit. The outer edges sit on, and make contact with, the outer ring, while the center is bulged upward over the center dot, not making contact (until pressed!).
Typically residue is coating the circuit board and metal device and preventing the electrical signal from bridging the two contact points.
Once the remote is opened, a white sticky film can be pulled back; the metal contacts and circuit board can be cleaned. Ensure the metal piece is oriented correctly before laying the film back down, and all is good!
Very helpful, I canceled the purchase of a new remote because of this. Thanks!
Amazing instructions, thank you sooo much! We were at our wits end as neither one of us can use the mobile app for lack of the infrared on our phones. We were to the point of throwing the TV out since it would be useless cause we didn't want to fork out that much money for a replacement! $65 and up for a brand new one! You saved us!! Again THANK YOU!!!
One of the part is heating in remote pcb that is A1SHB which is write on the part what is the soluation for this problum
اريد تغير ميكرفون ريموت التحكم سامسونج
Samsung 43" Smart tv - the channel up / down button does not work. The remote is ok because when I press the channel button and get into the tv guide mode the button works and i am able to scroll up or down with the channel button. I have tried the remote from my 50" tv and I still cannot change the channels. I assume the fault is in the tv. Any ideas on a fix ?
Thank you very much for this info, I never would have been able to do it without the information you provided. I had to put a very small piece of tape on each bubble under the left, right, up, down, and center push overlay to have them make contact.
Works like a charm now.
I'm getting a "Not available" message on the TV, when I use the smart remote. I was hoping there was grime but it looks clean on the inside. There a white mark on the Winbond W25Q40BWSNIG 4M Bit SPI Flash chip. Does anyone know if there's anything I can do? I've gone through the standard steps of replace battery, then to sync remote (which does not work), and reset remote full shut down if tv and remote. To no avail.
Anyone know the type of infrared led? Mine is missing.
Does anybody know how to fix a tactile button that stopped clicking (went soft or cracked, not sure about the physical root cause)?
Love this guide, help me out when I spilt some coffee on it.
Where’s the bluetooth chip at?
video or show how To fix a snap Samsung remote am if it you do The battery but it don't work what should we do
Even if I tried to change the channel it will not work something it will work but not all the time it will just stay like that we try to find it but it will not work so I thought that it was the battery but it was not the battery and I don't know what is the problem and how am I going to turn it off when we first got it it will perfect but six years later it not working am I don't know what is the problem today it was working a couple hours am boom it not working and now Blippi pop up out of nowhere i do I fix it, it like how am I supposed to turn it off when it night time help me and it it the battery or something else like what are I supposed to do with a six years old TV remote and TV it look perfectly fine and it's not working and yesterday it was working perfectly fine and now it just stop working and now we have to watch this Blippi video and now we can't turn it off when we are going to bed and then we have to pay the electric bill and it going to be higher like the TV is going to be on for hours help
I had this remote control open in 3.2 seconds without a guide or special tools. Using a small flathead screwdriver and shear catlike prowess I had it open, cleaned, and working within 10 minutes! It's not rocket science boys! I'm just a girl!!
I had to open my remote to fix a sticky back button. I opened the remote very slowly my 1st time, I used 3 different picking tools (1 picking stick, 2 guitar pick tools). I had to use 2 guitar pick tools at the same time, the first to open and hold open the clips, and the second to continue to open along the edges. If you don't hold open the remote with the picks, the clips will close again as you're handling the remote trying to open it.
After opening my remote, I saw it was clean, no dust, or food, or sticky residue, I cleaned the number pads with 99% alcohol and even dish soap water, but my back button would still stick. I inspected the rubber number pads and there was no cracks or holes, the remote looked brand new in the inside. Finally I fixed the button by grabbing a bit of sand paper, I rolled the sand paper like a cigarette and sanded the back button hole on the remote plastic casing. I closed the remote and BANG!! it was fixed, like brand new, no more sticky button, and feels better than new. :)
Please help, my voice control, no longer works. I think due to the remote being dropped. What should I do?
Meu microfone parou de funcionar alguém consegue me ajudar?
