Помощь
Gateway ID47H07u Teardown
Редактирование шага 8 —
Тип шага:
Перетащите чтобы изменить порядок
There are no screws that hold the front bezel to the rest of the screen.
Simply pick a corner at the bottom of the screen and pry the bezel from its binding clips around the screen. There is a little tape over the inverter board, but it is nothing you can not overcome already.
Make sure to release the clip that binds the hinge covers together, indicated by the second picture.
The front bezel is somewhat thin and delicate and can be broken if you are not careful.
To remove the screen, There are clips all around the screen that are pretty easy to work with just a Flathead screwdriver. The white plastic is part of the screen itself and should not be damaged when removing the screen.
Ваш вклад лицензируется под свободной лицензией Creative Commons .
