Помощь
ASUS MB169B Portable Monitor Teardown
Редактирование шага 2 —
Тип шага:
Перетащите чтобы изменить порядок
Lift the cover away from the LCD and set off to the side.
Remove the 4 screws holding the LCD to the back cover.
Do not attempt to remove the display at this time, as it is attached to the main board.
Turn the display over, you will see a cable connector attached to the display with yellow tape.
Pull up on the yellow tape to flip up the retaining bar holding the connector in place.
Pull the connector straight out away from the display.
Ваш вклад лицензируется под свободной лицензией Creative Commons .
