Помощь
Google Nest Audio Teardown
Редактирование шага 7 —
Тип шага:
Перетащите чтобы изменить порядок
At this point, the inner metal core is still sealed, but you should be able to see the main logic board (MLB). However, it's not necessary to remove the MLB to access the speaker. We're only removing it here because this is a teardown.
Gently pull on the plastic pull tabs with your fingers, tweezers, or pliers to disconnect the flex cables from the MLB.
Ваш вклад лицензируется под свободной лицензией Creative Commons .
