Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Laptop will not turn on
You cannot get your laptop to turn on.
Laptop is not charged
If the laptop won't turn on, you may have a drained battery. Plug in the charger to the device. It may take up to 30 minutes for your laptop to be charged enough to turn on.
Laptop battery is faulty
If your Laptop's battery is faulty you will need to buy a new battery for your laptop. If this is the case, your battery will need to be replaced.
Laptop will not charge
You plug in the charger and the laptop won't charge.
Charger is not plugged in
Make sure your charger is plugged in to an outlet, and that all other components of the charger are connect properly.
Charger is faulty or broken
Components of the charger may be worn or broken. Check the charger chord, computer connector, and wall plug for visible wear. Buy a new charger if these components seem to be broken.
Battery is faulty
Screen is black
No picture is displayed on the screen.
Computer is not on
Try turning on the laptop or performing a hard reset of the device.
Power problems
Try using a different AC power adapter to charge the laptop. You could also try completely removing the battery, as shown in this guide, and running on solely AC power.
Laptop shuts down
Your laptop is on and running when it suddenly turns off.
Laptop ran out of battery
Plug your charger into the laptop to restore power to the device.
Dirty or worn fan
Clean or replace the fan. To reach the laptop fan, use this guide.
Laptop freezes
You are using your laptop, when your screen freezes on one image.
Laptop has overheated
See overheating page below.
Processor is faulty
Check the power supply or check to see if any capacitors are bulging or leaking. Replace them if they are.
RAM is faulty
Replace the RAM using this guide.
Hard drive is faulty
Replace the hard drive using this guide.
Keyboard does not work
The keyboard will not type properly.
Key is jammed
Take the keyboard apart using this guide. Isolate the jam and use compressed air to unjam it. Reassemble the keyboard.
Particles have gotten inside the keyboard
Shake out debris or use compressed air to blow particles. If this doesn't work then you may need to replace the keyboard using this guide.
Laptop is slow
The laptop performs actions very slowly.
Poor wifi connection
Start by reseting your wireless router and modem. If that doesn't work, you may need to contact your wireless provider.
Laptop is overheated
The laptop is very hot to the touch.
==== Laptop overuse ===
If the laptop is used for an extensive period of time or performs many things at once it may get hot - and potentially be damaged. Close large programs and let the laptop sit unused for about 10 minutes.
Faulty fan
Find the fan using this guide and clean or replace it.
Faulty battery
Purchase a new battery to replace your current one. To remove the battery, use this guide.
No sound is coming from the speakers
No sound will come out from your laptop
Volume is low
Press the volume plus key to increase the loudness.
Laptop is muted
Press the mute button to un-mute the laptop.
Sound source volume is low
Many videos and songs that can be played on a laptop have their own volume dial. Check if that dial is low or muted.
Speakers may be broken
Use this guide to locate and replace the speakers.
Один комментарий
I have HP pavilion g6 and I upgraded it in core i5 with AMD 2gb graphics but when I play game it said please upgrade your driver but when I go to the website to upgrade my driver it say there is no update available. Please help
Naveen Meena - Ответить
