Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36478вопросов Показать все
keeps turning off randomly
sits for a few min and then it turns itself off. still has good battery life left and sometimes i have to put it on charger and then it reboots. When it comes back on the batt is fully charged. It will also do this just after a full nights charge.. any suggestions?
Это хороший вопрос?
Оценка -1
1 Комментарий
It sounds to me like an software issue. Do you have the latest Firmware installed? Or is it jailbroken?
из
Добавить комментарий
1 ответ
Выбранное решение
iPhones tend to be picky about batteries. Try installing your old battery and see if it goes away; if it does your phone dosen't like your replacement battery.
If you are still having issues, a recovery restore may help. Refer to this guide to restore the device. This will erase your data, so make sure you have a backup or don't need the data on the phone.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
chris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,028
