Power Button Broken - Gold Spring.
Hello,
Have been restoring my ipod back to its original condition (hardware) - After this the gold spring from the power button has broken off.
I cant find any reconstruction guides of this online, so i ask what would be a fix for this? (Not buying a new panel)
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
William Briggs, the spring connects the communications board with the power button. depending where it is broken, you could try to resolder it, or you will have to purchase an old broken iPod to harvest it.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Ohh so its only soldered on? If it is, that's ok for me to fix :) I thought it was spot welded on or something stupid :D
Thanks - Will
из
It is soldered. Apply some solder on the board, some on the spring and then solder the pieces together :-)
из
Добавьте свой ответ
William Briggs буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 648
