How can I fix this?
My Ipod touch 4th gen. screen was broken and I repaired it. Now when I try to turn it on, a white screen shows up.
Это хороший вопрос?
Счет -1
Добавить комментарий
3 Ответов
Выбранное решение
make sure all the connectors are connected and try doing a iTunes restore
Был ли этот ответ полезен?
Счет 0
do you sure the konectore scren put correctly? make sure the screen type corect too
Счет 0
If the LCD connectors are properly connected then try resetting your device by pressing and holding home and power button until the screen goes black and turns on again. If this thing doesn't help then you may need to go for LCD replacement.
Счет 0
1 Комментарий:
Did you bother to look at the date the question was asked? I doubt bakerkylee still has a problem here.
из
Добавьте свой ответ
bakerkylee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 227
