Where can I find replacement parts?
I have a zune hd that took a hit in a skateboarding accident. The device is fine except for the ribbon cable that connects the audio output jack. Where can I find a new jack / ribbon? (4 solder points and I'm good to go! If I could only find the part.)
I think I can make it work with small gauge wire... but I'd rather have the actual part. Any advice?
Это хороший вопрос?
Оценка 2
Добавить комментарий
4 Ответов
Выбранное решение
Check this page for guides etc., but for parts, you'd have to search ebay, amazon, etc., and you'll find plenty of parts all over the place.
Был ли этот ответ полезен?
Оценка 1
yea i need the same part myself, ebay doesnt seem to have it but i will keep looking
Оценка 0
Anyone still interested in parts go to:
http://www.rapidrepair.com/shop/zune-par...
or:
http://www.repairsuniverse.com/zune-part...
I have used both of these vendors with good results.
Good luck!
Оценка 0
I have a Zune HD that I replaced the digitizer on and I cannot find the correct adhesive to put it back together. I tried using a (I believe it was an iPod touch) 3M adhesive but it was too thick and the glass digitizer wasn't flush with the bottom panel. I've had my Zune HD in a vault for almost 7 years and really want to get it working again. Any advise would be much appreciated
Оценка 0
Добавьте свой ответ
Shawn Porter будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 8,674
