Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1502вопросов Показать все
What value is that small part near blue inductor?
Hello I have asked here earlier about BB crashes (What may cause BB 05.13.04 crashes? (unlocked by ultrasn0w))
I was missing that small part close to blue SMD part (probably both are RF inductors, but who knows) and I applied some sort of this fix http://matteopisani.altervista.org/iPhon...
My iPhone could not get service (BB was always crashing a it got service for maximum few minutes..), so I presumed that if it's low inductance inductor it could be replaced by blob, so I made tiny tin blob over it's contacts..
It helped a lot 70-80% of time I have full bars, but the problem is that it's very picky to location and wether I use GPS or WiFi... For example if I take elevator in malls it lose service and it takes 10-20 minutes sometimes even hour of Searching/1 bar/no service to pick it back..
It seems to pick it instantly if I open phone and disconnect battery and connect it back and turn phone on, but that's really useless when I'm not at home and can't open it up..
So my question is, what is that part I am missing? (http://matteopisani.altervista.org/image...) Is it really inductor? And if it is what value is it, I was thinking about unsoldering blob and either buy it at Farnell or in local "radio shack" or making my own by taking really thin transformer wire and wind it on needle.. But I have no idea what inductance it should have..
Это хороший вопрос?
Оценка -1
1 Комментарий
Hi there I have the same problem but now I've knocked the BLUE chip off and lost it..:( have you any fix or what the chip is called???? Thanks Dwain
из
Добавить комментарий
2 Ответов
Выбранное решение
Bruno Kremel , the part you are pointing to with you image is L3_RF = 7.5 nH, 5 %, 680 mA, 0.104 Ohms, 5800 MHz SMD/SMT 0402 (1005 metric) Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Thank you very much... going to calculate wire length needed for this.. :)
из
I have found it on Farnell, is it this http://uk.farnell.com/jsp/search/product... ?
из
Yes Sir, that looks correct :-) good Luck and thanks for accepting my answer :-)
из
Is this blue coil same for 3g / 3gs / 4 / 4s ?
Оценка 0
Добавьте свой ответ
Bruno Kremel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,109
