Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52вопросов Показать все
dropped ipad, bent the alluminium case on the volume bottom
I've just dropped my ipad and the alluminium case bent on the volume button, i cant use the volume button and it stuck inside (volume square is frozen on the sceen). Is it possible to open the ipad and reshape the allumium case or is it too risky?
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
Hi Lou,
As you have probably noted, there is no screw to open the iPad 2 and in fact it make opening this iDevice much more complicate that an iPhone for example.
This is the reason why all iPad 2 guides are marked "Very difficult"!
I wouldn't say it is too risky, it depends on you, your skills and probably also your tools. If you want to make a good job you will have to use the good tools. Look at this iOpener at least!
  • If you decide to access the volume button hole from inside the rear case, the minimum require disassemble is the display. Look at this guide so you will have a better view on what you would have to do.
  • Once you will have the screen out, you will have a better view if further dis-assembly is required. Any further dis-assembly should be piece of cake after what you've done just before!
  • Also remember that you're gonna have to re-install the screen with new adhesive strips after that. (New adhesive strips available here.)
Let us know what is your decision, and good luck!
iPad 2 Adhesive Strips Изображение
Продукт
$6.99
iOpener Изображение
Продукт
iOpener
$19.99
iPad 2 CDMA LCD Изображение
Инструкция
iPad 2 CDMA LCD Replacement
Сложность:
Очень сложно
40 minutes - 2 hours
iPad 2 CDMA Front Panel Adhesive Strips Изображение
Инструкция
iPad 2 CDMA Front Panel Adhesive Strips Replacement
Сложность:
Модерировать
Был ли этот ответ полезен?
Оценка 2
If the case is bent in the volume control area you can just use pliers to unbend the case. Be careful and use a cloth pad to avoid scaring the case. In my case (pun intended) the thin aluminum above the cutout part of the case was bent and Apple wanted almost as much as a new one to repair it.
Оценка 0
Добавьте свой ответ
Lou будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 5,748
