Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1502вопросов Показать все
Вопрос закрыт
Is 70% Isopropyl alcohol ok to clean an iPhone 3GS?
I was caught in a heavy rainstorm about 3 days ago and my iPhone died on me. I opened it up when I got home and dried off the components with a soft cloth as well as ordered a new LCD & Digitizer and installed those.
The screen works as it should but the backlight is still inactive.
My question is: Is 70% isopropyl alcohol enough to clean the logic board and connectors of the 3GS? I was planning on following the guide posted on this website inorder to do the fix but was just wondering if 70% was too little of an alcohol concentration.
Thank you for any help you may be able to provide.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
No. 70% isopropyl is 30 % water. Use methanol.
Был ли этот ответ полезен?
Оценка 2
6 Комментариев:
So if I were to soak or brush the contacts with it it would just ruin the phone further? Also, would 90% or 99% be the right choice then?
из
90% + should be fine.
из
And 90%+ is available at places such as Target or Walmart correct?
из
Andrew Novotny, I get my stash of 99% through my local pharmacist. The larger retail stores are not really good in getting those items, not a big selling item for the.
из
I don't know, I use Methanol. Call them.
из
Показать 1 больше комментариев
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 9
За всё время: 1,703
