Lots of great information here, but having solved a number of these cases I'd just like to add:
1.) It is NOT connect the dots---the line represents the underlying continuity that is present in the original. If you have ripped off a pad, all you need to do is build a thin wire jumper to restore continuity from the pin/pad to the right line---not re-create a whole new trace on top of the board.
2.) It is probably not a good idea to have exposed jumpers on the vBatt line unprotected in a phone that you are holding near your face. but that's just an opinion.
3.) The four capacitors are non-essential (from experience). You can get away with knocking them off and not notice any defect.
4.) The two resistors are essential---continuity requires you a path through them. If they are gone, you must make a thin wire jumper to connect their two pads.
5.) The most important thing is continuity. Just test from the battery connector pin to the end of the line and see if you get a beep with your multimeter set on continuity testing. If yes, you're done. If no, you have a mistake.
6.) The battery connector itself should never not have continuity between pin 1 and pin 4--if it does, you have an internal short in the phone and this is the reason you're phone won't boot.
and lastly---
if you get in trouble and need a DIY rescue service, feel free to give me shout via my profile.
Jessa
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
5
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Комментариев
Unfortunately old turkey... The job failed.
I accidentally ripped off the battery connector off the board and now one of the gold pins is missing from there. So now I'm calling the quits haha. Anyways I hope apple will still accept my iPhone as an out of warranty device for 200$.
Thanks for all your help though man, I don't know what to say :)
из californiaxfresh
Darn, I am sorry about that. You don't think you could fix the solder pad? Sometimes, we all have to cash in our chips and call it quits....I do wish you better luck next time.
из oldturkey03
