Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1502вопросов Показать все
Вопрос закрыт
Why wont my iPhone charge, even after replacement?
My Iphone 3Gs wouldnt connect or charge to my charger but my sisters would so I knew it was my phone, I thought that my battery blew so I replaced it and everything turned on and worked but it still would not charge, I put it in restore mode and then put it on my ihome, it recongnized it and turned on but still no charge.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
mrvalenzuela119, normally I would say to start with your dock connector. Check to make sure that the proper pins receive power. Check the pinout on here. If that looks okay, check the "fuses" on the logic board for continuity, it is possible that your charging fuses is shorted. After that it could be your PMIC or charging coil. All of those are of course board level repair and require some good skills, good tools and a lot of patience. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 264
