The S1 to SX60 series (also called the SX series or Super Zoom series) consists of ultra-zoom cameras with longer zoom ranges and a more extensive list of features. The SX100 and SX model cameras are a more compact, affordable spin-off of the S/SX series.
243вопросов Показать все
lens error restart camera canon powershot sx100 is
what happen if we plugged 5.0v charger at the place of 3.5v in canon powershot sx100 is
camera is only showing "lens error restart camera "
and getting off.And lence is remained opened.
Please help...!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
mak, it is possible that your lens is either stuck or that the power surge damaged the DC-DC board. There are 3fuses on the logic board (check image) check those for continuity first. FU601 and FU602 are UNHS206 and FU603 is a UNHS203. If those fuses are okay, check the optical flex cable for any burned or missing components. The last thing to do would be to replace the lens itself. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
mak будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 2,104
