Should I replace the Hard Drive?
Tried to troubleshoot and nothing happened,I inserted disk tools 7.5 and used disk doctor and It couldn't find the Hard Drive, Where would I find a new hard drive for this?
the one it has is (in my opinion) completely unreliable
please take a look at my other question too
thanks,
Это хороший вопрос?
Счет 1
3 Комментариев
Are you getting three bongs on start up?
из Поделиться
no, 1 bong it starts up, then sits for 5-7 minutes, then it just goes wild and I have to turn it off
из Поделиться
Mayer, Your descriptions of your issues are exasperating. "Goes wild", tells me absolutely nothing. You're very hard to help. SO I'LL JUST LET SOMEONE ELSE TRY TO HELP YOU.
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
You'll probably need a new hard drive for it. Especially if the install floppy cant find the HD.
Your best bet would be to scour eBay for a replacement.
Also, if you've ever done any sort of hardware repair on a computer, you shouldn't have any problems replacing it. Those old macs were meant to be serviced.
Был ли этот ответ полезен?
Счет 1
Этот ответ изначально был на другой вопрос.
You'll need a 1/3 height SCSI hard drive. This is just a standard size drive.
Счет 1
Добавьте свой ответ
Ted Mayer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За все время: 534
