Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
iPhone 4 network searching.No Network
Hello just like to ask.
Could this iPhone 4 logic board get fixed.The phone is not blocked but just seems to show network searching and can't pick up a signal.
I think there could be a problem here no to sure tho.
Это хороший вопрос?
Оценка 2
2 Комментариев
Yes them 2 chips are not on.I have them tho can take them of a spear board i have.Hmm now just need the soldering skills
из
Your image is a bit out of focus, but it does look like somebody applied a jumper. Remember that this ha now become common practice. You can get a circuit writer pen to close the loop if you have trouble soldering those very small pieces.
из
Добавить комментарий
Ответов (4)
Выбранное решение
Your antenna coil is disappeared. If you replace it you will most likely have full signal again.
http://www.ebay.nl/itm/Apple-iPhone-4-Bl...
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
i have the same problem with iphone 4s simfree , he read the simcard but away searching.... any sugestion?
Оценка 1
iphone 4s network searching poblam
Оценка 1
make sure your time and date is correct that will fix it unless the black service wire is faulty or the clip is goes into is broken
Оценка 0
1 Комментарий:
Thanks did the time and date still not working.Wire is fine.I been looking at a few pics and it seems am missing the blue coil
из
Добавьте свой ответ
Hal будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 26,196
