Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2396вопросов Показать все
iPhone 4 network searching.No Network
Hello just like to ask.
Could this iPhone 4 logic board get fixed.The phone is not blocked but just seems to show network searching and can't pick up a signal.
I think there could be a problem here no to sure tho.
Это хороший вопрос?
Оценка 2
2 Комментариев
Yes them 2 chips are not on.I have them tho can take them of a spear board i have.Hmm now just need the soldering skills
из
Your image is a bit out of focus, but it does look like somebody applied a jumper. Remember that this ha now become common practice. You can get a circuit writer pen to close the loop if you have trouble soldering those very small pieces.
из
Добавить комментарий
4 Ответов
Выбранное решение
Your antenna coil is disappeared. If you replace it you will most likely have full signal again.
http://www.ebay.nl/itm/Apple-iPhone-4-Bl...
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
i have the same problem with iphone 4s simfree , he read the simcard but away searching.... any sugestion?
Оценка 1
iphone 4s network searching poblam
Оценка 1
make sure your time and date is correct that will fix it unless the black service wire is faulty or the clip is goes into is broken
Оценка 0
1 Комментарий:
Thanks did the time and date still not working.Wire is fine.I been looking at a few pics and it seems am missing the blue coil
из
Добавьте свой ответ
Hal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 26,151
