Model No. A1367 / 8, 16, 32, or 64 GB capacity
915вопросов Показать все
Вопрос закрыт
Why home Button unresponsive after I replaced the ribbon cable?
I bought the home button ribbon cable to replace it on My itouch 4th gen. I followed the directions exactly like I was supposed to but when I turned it back on the home button sill didn't work. It clicks like it's supposed to but it is not responding. What did I do wrong?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Maybe you've broken the ribbon cable connector, it is very VERY frail.
But before you change it, it was working sometimes or not?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
It didn't work at all. The silver button on the old ribbon cable was completely gone. It felt as if it was jammed.
из
Sorry but i noticed only now that you are repairing an ipod, and not an iphone.
You may have done 2 mistake.
1-You haven't fitted fine the ribbon on the steel mid plane, or you haven't placed fine the mid plant on the ipod.
2-You have broken or you have dirtied the contact.
Maybe you could also have fitted a broken parts but it is very unsual. Unmount the device, try the button with a tester and when reassembling take more attention to put the ribbon in correct position, and clean the contact between the ribbon cable and the logic board.
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 87
