Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
48вопросов Показать все
Any way to unlock cheap thumb drives from tradeshows?
I picked up a handful of thumb drives from a client that went to a trade show. I'm sure they are hardware locked even when gparted won't delete the partition or format the drive. Anyone found a way to unlock these?
They would be nice to recycle for linux installs.
Это хороший вопрос?
Оценка 4
1 Комментарий
Can you give us some info on the drive. Also, did you try googling the company that preps these drives (if different than the supplier of the drive) to see what they offer as a service? trying to reverse engineer what they are up to here.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
It is probably possible. Try opening them, and look for any write protect switch or chip. If not, this may help
http://www.spotht.com/2010/08/how-to-for...
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Country Computer Service будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 755
