Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
Liquid spill causing logic board issues
early 2011 17" unibody Macbook pro 2.3 GHz intel core i7
The kids won't fess up to exactly how liquid got into my mac but i noticed liquid in it when i took the back off. It wouldn't charge or boot up at all so i removed the logic board and cleaned it. I got it to charge and boot up but only a few keys work properly and there is a band running through the monitor and it is making a strange sound like a (musical)horn the mouse will bounce around and other sporadic glitches. any easy way to fix it?
Это хороший вопрос?
Счет 1
1 Комментарий
yes the external keyboard and mouse work and the track pad seems ok its just all the sudden it will make that sound then things go berserk for awhile, sorry i don't have much technical jargon, i'm very new at this fix it myself stuff was tickled that i got it boot up at all. And ya i backed everything up right away. i have set up the sweat box outside and if someone doesn't start talking soon it won't be cookies they are begging for!! i just cant afford to send it away to get it fixed right now and i desperately need it for work. and now the monitor looks a negative photo, thats just a new glitch. how hard is an upper case replacement?
из
Добавить комментарий
1 ответ
Выбранное решение
Try using an external USB keyboard and see which issues persist. Let us know your results. If you don't have an external backup drive, get one and back up your hard drive ASAP. Sounds like a minimum of an upper case replacement. Use water boarding to extract information from the kids about what and how much liquid got into it: https://en.wikipedia.org/wiki/Waterboard...
If waterboarding seems to extreme, here are 10 other forms: http://www.howstuffworks.com/five-forms-...
or you can just give them some cookies and coach the info out of them.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Here's how to replace the upper case on your machine: MacBook Pro 17" Unibody Upper Case Replacement
из
Добавьте свой ответ
jennifer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 156
