memory RAM stuck inside at the bottom slot
So basically, I did a mistake when I tried to upgrading my MBP memory RAM. After I removed the original RAM, and when I tried to install the first RAM to the bottom slot, it did not installed correctly but I already pushed it too hard so now it just stuck there without being recognized by my MBP. Then I continued to install the second RAM into the top slot (each 8GB). Then when I turned it on, it says that the RAM is only 8GB instead of 16GB (obviously the bottom RAM did not installed correctly that's why).
So now my question is, how to remove the stucked memory RAM out from the bottom slot of my MBP 15" mid 2012?
Thanks in advance,
Tobi
Это хороший вопрос?
