iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
iPod stuck on pause
Hi I have been using my Ipod in my car, and now I have a problem, it stopped working and I can not do anything with it, it is charged but it is constantly showing pause on the screen, it is not locked, I can not turn it off and the click wheel does not do anything, the screen is lit all the time, none of the controls do anything
regards Roy
Это хороший вопрос?
Счет 1
1 Комментарий:
Is it still being recognized by your computer when you plug it in? If nothing else, remove the battery and then reinstall it and see if it starts back up. If so, try the diagnostics mode and check for any errors.
из
Добавить комментарий
1 ответ
connect it to itunes and do a factory restore on it, it may be software corruption, if not strip the device and use WD-40 contact cleaner if this doesnt solve it there may be a chance its the logic board
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
royhill44b буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 1,059
