The Mac mini family was first introduced in January of 2005.
1251вопросов Показать все
Type E power cable for Europe
I just got a 2012 Mac Mini for my friends in Europe. They would require a Type E power cable and I was wondering where I'd go about getting it?
I'm not sure an adapter would be the best option for longterm use of a computer that's always running. Suggestions?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Not to worry you have a few options here.
First your mac uses a two prong non-polarized electric razor cord 2.5Amp @250Volts {15Amp @ 120Volts} Type C. Which allows you to use standard travel AC adaptors.
The best solution is getting a Type C power cord. Not a Type E as you don't need it, there's no ground service present in the Mac mini, or a Type F as you don't need polarization either.
The correct cord is a IEC C7 (at any angle) with a CEE7 on the other side.
Here's a good source for any cord need SignalandPower.Com
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you Dan. You've been very informative.
из
Добавьте свой ответ
Erik будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 899
