Hewlett-Packard began manufacturing personal laptop computers in 1993.
blank screen hp2000 notebook
my hp 2000 notebook screen is blank.it will work with external moniter connected
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi joe,
Your graphic card unit on the motherboard (integrated) still works. That is a good sign. So, its seems that you need to replace the LED LCD unit.
If the notebook is no longer under guarantee, I would give it a try and invest in a new LED LCD unit. You find one here or here for around $50.
A replacement guide you find here or here.
Steffen
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
thankx for your knowledge I wanted to make sure this is the problem .before I buy a lcd
из
joe, make sure that it is not just your backlight that is out. Shine a light at an angle against the screen with your OS displaying something like the Desktop etc. If it is your backlight, you will most likely only need the inverter. Also check your cables, make sure those are still connected properly. Hope this helps, good luck.
Счет 1
Добавьте свой ответ
joe буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 392
