Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Это хороший вопрос?
Это хороший вопрос?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Был ли этот ответ полезен?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
За последние 24часов: 5
За последние 7 дней: 20
За последние 30 дней: 48
За всё время: 11,294
1 Комментарий
Thanks oldturkey03! I will check this out immediately.
из Berry
