Water problem help fix?
my tablet has fallen in water, I immediately took it out and left it, it start then restarts every one minute, one guy told me to leave it for 1 week nd then it will start working, is it true?
Это хороший вопрос?
Это хороший вопрос?
Joe, "to leave it for 1 week" will only ensure that you have a more corroded logic board. First I would no longer try to charge the device or try to turn it on. I suggest that you disassemble your device completely. Then clean each and every part with some high grade (90%+) isopropyl alcohol, this includes all the cable connectors. Once it is cleaned, replace the battery, reassemble your device and re-evaluate. Hope this helps, good luck.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 685
1 Комментарий
i have same problem :(
из ammar
