1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
macmods adapter - use
Hi, Im using the macmods adapter and have some questions, (Im apologize about my english):
Do someone knows if its ok to connect to 1 tube lcd an inverter designed to feed 2 tubes?
The imac intel inverter its connected to a original 2 tubes lcd, but the macmood includes an Y adapter to use a single tube lcd as replacement, I notice that the one tube lcd I use goes to hot on the bottom (where the tube is placed) and perhaps is cause the inverter doubles the current nedded for the tube.
I dont know to test it, I mean how to measure and compare the original current on the 2 tubes lcd vs the 1 tube replacement lcd.
Thanks a lot
Alvaro from Uruguay
Это хороший вопрос?
Счет -1
1 Комментарий
It might help if you can give us more information about the macmods part (post a couple of images) and where you got that part from.
из
Добавить комментарий
1 ответ
Выбранное решение
I think this is a question you should be asking the vendor/manufacturer. You'd be much more likely to have people with experience and knowledge of this 3rd party hardware there than here.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Alvaro B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 135
