Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
iPhone 4s will not power on...
OK, so its been a while since i used my iphone 4s. its been in parts for about a year and I just recently bought all new hardware for it. The hardware I replaced goes as follows:
Proximity sensor
Home Button cable
Charger port
Battery
LCD Screen
I pretty much replaced everything in relation to power. I kept it on the charger for about atleast an hour. At most, the IC's under the camera warms up, but no other responses. The computer doesn't even read it, which is how i know it has not powered on. There was no water damage because i strictly took it apart to replace the exterior, but just got lazy. I also tried researching the schematics, perhaps I can try to find out where the flow of electricity stops, but its really hard to find. Looking for suggestions...
Это хороший вопрос?
Счет 1
2 Комментариев
Right now i have no clue what to do...
из
after researching, i think my battery connector might be faulty... i will check and continue to update...
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I truly think that your problem is the same as mine! In my opinion it's either the mother board that has a short circuit OR the grounding thingies that are supposed to be mounted a certain way and we're missing it...
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
in desparation im gonna try placing the grounding cables and pray... i miss my iphone :(
из
Добавьте свой ответ
gtcoodyscoops буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,025
