Why wont my engine fire or run?
It will turn over. but it will try to start up on starting fluid. tjen it quits trying to run just turns over. whats wrong??
Это хороший вопрос?
Это хороший вопрос?
I would suspect fuel delivery system and the high voltage circuitry.
Был ли этот ответ полезен?
It has all kinds of fuel pressure. and yhe high voltage circuitry? how might i check that?
Search this site: bobistheoilguy.com Look in the Automotive and Mechanical forums.
You will also need basic voltmeter and ohmmeter test equipment.
i have almost the same problem my dodge neon wont even turn over it doesnt even do a click what do i do ? can anhy body help me
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 15
За всё время: 574
similar problem on our car turned out to be a loose fuel pump connector..
из pollytintop
