Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
Вопрос закрыт
Battery sometimes fails to properly charge
I've had this computer for a couple years now, and it's still running strong. The battery still gives me 4-5 hours charge, which is fantastic. The only problem is that sometimes the battery refuses to charge when my laptop's plugged in and the battery still has a good amount of charge (somewhere between 90% and 50%). Also, if I'm charging the battery from a lower charge, it sometimes refuses to finish charge - it says "Finishing charge" (or something like that, I'm not looking at it right now). What do you guys suspect the problem is?
Это хороший вопрос?
Оценка 0
1 Комментарий
I read somewhere that this is a known problem with the logic board. My macbook 2007 suffers from the same problem.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
sounds strange - maybe the battery gives wrong data to the logicboard
did you try coconut battery to determine the original capacity vs. the current capacity
are you able to try a different battery - maybe it works normal with a different one (or not - that way you could rule out a battery problem)
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I haven't attempted to use another battery, but my sister has the same style MacBook, so I'll definitely give that a try when I get the chance.
из
I haven't gotten any resolution with this, but I don't have the problem anymore. Perhaps just cycling the battery several times / the passage of time / software updates fixed it. Either way, I'm upvoting this answer so that the question is no longer "unresolved".
из
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 1,132
